Launching at the track
You guys dumping the pedal or slipping it a bit and letting it roll out?
Wanna know about street cars that hit the track, track cars, you do your thing, this is a 90% street car.
Well, i am running a stock DS, so i am going to keep my method till i get a stronger unit, then, i will have to try you guys method, LOL.
What pinion angles you guys set up for? I am at -3* right now.
https://ls1tech.com/forums/eastern-m...ay-new-pb.html
Due to race weight, you need to leave like a hero, flat out. Meaning it is time to main up to a good DS.
Since this post I have added Adj shocks all around, UMI Drag Bar, and Trans Relocation kit, a host of other things. JL-Ws6 still is trying to get me to gut the car, put on Carbon Fiber door skins and Kirkeys so beleive me there is more to go.....
Anyone use a Centerforce DFX clutch? Mine is doing very well and after i rebuilt the trans, i looked at the clutch disc and WOW, i have allot left for beating on it for a year, LOL.
Also, when you say slipping the clutch, does that mean you have the cluth pedal so the clutch is only somewhat engaged, so it slips to prevent such a large amount of power to be transmitted? If I'm correct, how long would you say you slip the clutch before releasing? .1 seconds, .25 seconds? From the sounds of it, it takes practice. Lastly, wouldn't 'slipping' the clutch wear out the friction material more so than just quickly dumping the clutch? I'm guess it causes more clutch wear, but saves the drivetrain from a violant jolt?
Also, when you say slipping the clutch, does that mean you have the cluth pedal so the clutch is only somewhat engaged, so it slips to prevent such a large amount of power to be transmitted? If I'm correct, how long would you say you slip the clutch before releasing? .1 seconds, .25 seconds? From the sounds of it, it takes practice. Lastly, wouldn't 'slipping' the clutch wear out the friction material more so than just quickly dumping the clutch? I'm guess it causes more clutch wear, but saves the drivetrain from a violent jolt?
Slipping the clutch is controlling the amount of clutch you release and yes, it does prevent such a drive line shock like side stepping. It dies use a bit more clutch material i am sure, but nothing noticeable if you have any decent gear. A 2.73 gear and slipping it HARD to achieve the best 60 foot possible will use some clutch life because there is allot of friction trying to roll out. A deeper gear, 3.73, or even better 4.10 or more does not require you to slip much before 100% engagement, due to the car being able to roll out with the extra gearing.
Hope that helps.
Otherwise, heal toe is not the same.
That gave me 1.65 60' with a 300 whp motor and 1.50 with a 150 shot.
I will do the same with my camaro. I have a Strange 9" BTW.
