Tick master adjustment
A: Our Tick Performance Adjustable Clutch Master Cylinder Kit uses a bigger bore than your factory master cylinder in order to flow more fluid. As a result of this, your pedal pressure will increase by ~15%. This is a GOOD increase that results in a much better feel for the clutch.
When you adjust our kit, you're actually adjusting the amount of fluid that the system flows. As a result, your clutch pedal could be noticeably shorter than it was with the factory cylinder - this just depends on your particular clutch setup. This is another GOOD feature because it results in quicker shifting.
You'll notice that the car goes into gear much easier than before, and shifting will be much more smooth as well.
A: Our Tick Performance Adjustable Clutch Master Cylinder Kit is the most comprehensive kit on the market. It flows more fluid than any other kit, is more adjustable than any other kit, and you get more for your money with our kit compared to any other kit on the market.
With our kit, we call it adjustable because you're actually adjusting the amount of fluid that the sytem flows. You've likely seen people modify their stock master cylinder to be "adjustable" - unfortunately, all you can adjust with this setup is the dead space in the pedal. There is no way to make the factory cylinder flow significantly more fluid. The RAM Adjustable Clutch Master Cylinder for the F-Body and Corvette is simply a modified stock master cylinder. This will not cure any serious clutch disengagement issues.
I understand that the adjustment is done so that the slave moves properly and that adjusting after the install could cause your clutch to drag.
Now I confused because I still have alot of dead space in my pedal. The first half of my travel is nothing. The clutch doesn't start to grab untill half way out. I thought that I could make it engage earlier by adjusting but from what that says it will only adjust the amount of fluid that is moved. My car doesn't seem to shift any easier or go into gear any easier neither. I haven't hit a full throttle shift yet though still breaking in .
I dont think you are going to achive what you are lookin to do, by adjusting your clutch pedal to get a different engagement area. Adjusting the rod is going to send more fluid to the slave pushing the pressure plate off the disk farther which will make it easier to get into gears and save your sycros.
What clutch setup are you running, you may want to compare it to someone with a much similar setup like your first,.
This sounds a lot like normal behavior and how my Tick master feels.
And honestly, I'd still try doing some more bleeding. Even with the pedal return spring still installed with my Tick master, the dead space is what I would consider minimal, but that took bench bleeding and bleeding with a Motive Power Bleeder (and I also worked it over with a MityVac just to make sure).
