Clutch grab high. Clutch going?
Wow so with 50+ views NO one can say?
The SS seems to have everything OE. He claims the trans had a recent rebuild and it is smooth.
I've yet to wear a clutch out on an Fbod and both my other T56s grab low and I like it. Is it maybe the clutch isn't shimmed?
Well, it is certainly possible that the clutch is worn out. High pedal engagament would normally evidence excessive clutch wear. Of course other info is important. Does the car have ab adjustable Master? This wouldn't be relative to the lack of a shim. Is the car using an LS7 clutch kit. If so, they don't require a shim for use.
Looks like you'll be in the market for a new one. www.diamondclutch.com
I give all LS1Tech members a discount and free shipping.
Also my stock clutch is grabbing pretty late/high but i have the ticks master cylinder. It still shifts fine and hasnt slipped as of yet. Should i be ok to race it 1 or two more times for the rest of the year or do you guys think its completely shot?
