T56 in 70 Camaro
I'm looking to swap in a LS setup and T56. I've come accross a few T56 but most have been out of the CTS-V. Is there any advantages or disadvantages, issues with install, or hydraulics needed to finish it off vs. one out of a Camaro?
I'm not looking to get real complicated.
Thanks!
Thanks!
I put one in a 1981 Trans Am. The things that made life easy on this swap were:
other nice-to-haves:
The trans I went with came from a 1998 Camaro. It fit well, but I did have to beat on the tunnel a bit and do some cutting. But then, you'll have to do this with any T56, I think.
- a master cylinder mounting plate from Detroit Speed (35-40 bucks)
- a new adjustable master cylinder
- a remote bleeder hose for the slave (also new)
- 2nd Gen F-Body Clutch & brake pedals from Classic Industries (just over 100 bucks, if I remember right)
- a TransDapt T56 conversion trans cross member
- custom aluminum drive shaft
- buying a clutch from one of the MFGs represented here (I got a Spec 2+) - Seriously, having that deep level of tech support is incredible. Jeremy has been a life saver.
I just finished one in my 79 T/A and didnt require any tunnel beating.... and the transdapt xmember didnt clear my exhaust, so I went with a G-force... bolted in to the factory holes... so if anybody wants a transdapt 3" drop I have one.... sell cheap too..
i know that this post is old.... however i find it very relevant... im starting to do this to my 79... ive got a t56 from a 96 z28... and i am curious to how hard this was to do... and if i get everything together before i go to do this.. can this be done in a weekend while on a lift?
93-97 T56s from camaros and trans ams wont work with a LS motor unless you have it converted which requires the change of the input shaft (longer), mid plate, and bellhousing. 98-02 is a LS specific trans.
I did the swap on my 83 Z28 with a SBC the only real difference between any other swap is you'll need a swap flywheel and a starter for that 153 tooth flywheel, and when it comes to the issue of the speedo a few people make conversions to the extension housings to work a cable drive, thats what I did, others use a dakota digital box
