BAM!!!! no Pedal wth
so here we go , same clutch wont disengauge just like a million other threds my question is after reading so so so so so so much i feel like i need whole new everything hydrilics wise lol do drill mod and buy a tick adj lol. I just dont feel like i could do the meausurement corrrectly for the slave side. i get the where to measure but really how do you get the caliper flush with the flat part that is underneath the slave???? i have a spec 3 clutch and put the .180 shim and still no disengaugement, im about to take this trans back out and i really dont know what is left for me to do inspect try to remeasure? drill mod, tick master, put the auto back in!!! please help
How does the pedal feel? If it is loose or sloppy you may have air in the system. If you have good movement in you slave cylinder then you may need to measure again. Use a depth micrometer for the measurement.Then make sure everything is correct and it should work. If all those basics are OK then the pressure plate must be defective.
so i kept bleeding using multiple methods pumping and pumping........... and BAM!!!! NO CLUTCH PEDAL wtf......... did i blow out my master cyclinder? well i dropped the tranny and found my slave bolts were loose.......after futher inspeection they were stripped so im gonna tap it out to a 7mm later do. does anyone think that was just my problem? i have a spec 3 clutch is there an average shim to use?
If the slave is not secured this could certainly affect release. What are you measurements? I know you reference difficulty in measuring but if you give me a call I will be happy yo talk you through this. Thanks!
