HELP! T56 mainshaft too long for LS7? Whats wrong here
I have bought D&D LSX specified viper case T56 and i has LSX bellhousing. Now i have finally got my engine 2012 LS7.
The broplem is at the main shaft bottoms against pilot bearing in the crankshaft end about 10 mm - 3/8" too soon. Bell housing has about 10 mm gap and there is now way i could install the transmission all the way.
What is wrong here? Is it possible to tap pilot bearing about 10 mm deeper? Or do i need adapter between bellhousing and the engine?
X2 on the pilot bearing. I had this issue with mating a 1999 F-body T56 to a LS3 crate engine. I had to switch to the LS1 style bearing so it would fit properly. I think
85MikeTPI is right. Need a pilot bearing to match your input shaft.
TJR
TJR
LS1Tech Premium Sponsor
Like everyone else said, you have the wrong style pilot bearing in the crank. We just ran into this on our 434 LS2 69 Camaro.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Hello guys,
Thank you so much for help so far
Could it really be just the pilot bearing? If so is there smaller bore behind this pilot bearing where smaller one could be fitted?
Here the pic
Here the pic
Yea deffinately the wrong pilot bearing, the ls1 bearing is tapered to allow the input shaft to recess in further.I also recomend you get a brass pilot bushing from a ls1 availible from advance auto or whatever big chain autoparts store is local to you it is better for higher horsepower applications and less resistant to wear.
