Automatic oil in a manuel transmission??
So is it true that you need to put Dexron iii in your t56 borg warner 6 speed transmission even though that's oil for a automatic transmission??
If your wondering why i posted this thread my mechanic told me that the m6 runs on automatic oil and i was shaking my head??
Nothing wrong with synchromesh. Many people on this board have used it with great results.
The reason for atf in most manuals today is the design of the synchros. The friction material is the same used in the clutch packs of an automatic which require atf to work correctly. Gear oil will just not cut it in a modern synchronized transmission.
So is this the reason why my gears don't go in at high rpms when I'm running the car at full potential i try to shift at 6 grand and the gear won't go in??? I thought it was my synchros or the master cylinder or slave master?
well you should never put synthetic anything in a stock t56 if you look on the side of the transmission you will even see a sticker that says dexron III only. anyway you may have messed up the synchros with the gear lube as it will not let the synchros catch and may cause hard shifts also.... remove it immediately and fill it up with synchromesh or some type of good dex III atf fluid.
Oooooh the sticker must be 'obeyd' Doesn't the oil filler say Mobil 1...Ohhhh no! all those poor stock engines that have anything synthetic in them.
![GTFO](https://ls1tech.com/forums/images/smilies/gtfoslap.gif)
Umm please do research before you post... I didn't say it wouldn't work I just said it shouldn't be done because as was stated t56s before late 2001 used paper synchros and synthetic fluid does not allow the synchros to function properly... And yes the sticker on the side of the tranny should be obeyed.. Dex III is the fluid it takes not VI, II, or type f i dont recall saying anything about a brand though... And the filler cap does not say Mobil 1 only corvettes had that cap
![Post](https://ls1tech.com/forums/images/icons/icon1.gif)
It's a very real possibility the synthetic isn't a proper break-in fluid for a carbon blocker ring trans. And frankly, if the car isn't being pushed hard upstairs with a lot of power, the synthetic isn't going to be as effective at protecting the headset gears as a sprayer setup.
Don't automatically assume everything synthetic is better for every situation.
