high pitch whine
If its a whine, I would say it is in the transmission. If it is more of a squeal, it is more than likely a bearing. Pilot bearings will usually make noise in between shifts where the transmission input shaft is forced to break speed with the engine crank shaft.
![Huh](https://ls1tech.com/forums/images/smilies/LS1Tech/huh.gif)
I always like to rub a little bit of high temp grease in there regardless of what any directions say. You just don't want to put too much or you chance getting it on the clutch disc surface which will ruin it.
