Tried much, still cant pull 5th/6th cluster
Heat, penetrating oil, voodoo.. still cannot pull it.
I keep breaking teeth off the gear and breaking the puller. Ideas?
theres no snap ring or anything holding it on so..
Are you talking about the driven gear? If so it's possible the splines have worn into each other and would require a small twist in the opposite direction of normal tq. Mine was completely loose and slid off by hand so I cannot help too much. Maybe a really big snap-on puller at a shop?
If so, clamping bearing puller upside down (so it's resting on the flat side rather than on the taper) under the gear and pressing the main shaft thru may work.
