Still have problem after bleeding clutch
Here's what I did:
- with the car off I had a friend pump the clutch several times, then hold it to the floor.
- I opened the bleeder until fluid stopped coming out, then closed it
- refilled the reservior
- repeated above steps probably 10 to 12 times
Once we were done I started the car to take it for a test drive, but couldn't get it into gear. The clutch pedal actually felt a little worse than before I bled the clutch. In addition, during the bleeding process, the clutch made a loud squeeking sound every time my friend pushed it in.
Did I bleed the clutch incorrectly? Or could I possibly have a bad slave cylinder?
Any thoughts would be appreciated.
Thanks,
Jim
I got fancy on mine and used synthetic brake fluid, and the clutch hydraulics evidently hated it. Very hard to get into gear, and w/ the car on stands you could see the rear wheels start turning when I went into 1st gear.
I purged the synth fluid and installed regular Castrol brake fluid...same bleeding procedure again, and it's been happy ever since.
No clue why the synth brake fluid did what it did.
I do nearly same procedure as you listed, except for the following:
1) I have my friend release the clutch pedal after I tighten the bleeder.
2) I use my MityVac w/ conical tip to vac-bleed the master cyl via the reservoir.
I just wanted to make sure I was bleeding the system properly and it sounds like I was.
I used the standard DOT 3 Brake Fluid.
I may try bleeding it again this weekend. And if that doesn't work I'll probably try bleeding the master cylinder. At least it will give me a reason to buy another tool (MityVac)
Thanks again,
Jim
Thanks,
Jim
The reservoir was empty. When refilling, the fluid basically went straight from the reservoir to the concrete.
So, as I type, I'm getting the updated master and slave installed. The stock clutch was apparently used up too, so a new SPEC 3 with aluminum flywheel is going in. The stock 99 clutch and hydraulics lasted longer than I thought... 60K.
Your circumstances sound similar. So good luck.
Here's what I did:
Thanks,
Jim
I'm convinced that there is something wrong with my hydraulics. So I'm planning to replace the slave cylinder. Unfortunately, I don't know how to do this so I'm going to be posting another thread asking for advice. Feel free to chime in.
Thanks,
Jim
Here's what I did:
Thanks,
Jim
by the way i put a centerforce in my 99. i used the stock slave and a stock 97 master the pedal stop had to moved up so the clutch pedal sits forward the brake pedal about an inch. but the clutch works great.neither the 99 or an 02 master worked just couldn't shift quickly it always ground.
hope this helps, matt
