What RPM do you shift at while racing?
I have my shift light set for like 5500 just to leave me some room for error. Do you shift higher then that? or is that a good shift point while running hard.
is ur WS6 stock?.....b/c i have a .581/.581 224/224 112LSA custom comp cam and shiftin at 5500 in a decent race would be sellin my self short on power(as max for the cam i have would be better for me to shift at 6300).....but if u are stock u need to change that settin to 6000...lol these cars stock can take an ALL out punishment....u can leave it the way it is if ud like but stock LS1's max there hp at 5800
with stock cam and stock tune set your shift light at 5800 so by the time you shift you will be at 6100 then shift a lil afte the shift light on all the other shifts
Actally stock cam cars build peak power at 5200 rpms. After that they begin to run out of breath. Just shift your car at 5800 rpms. The only reason people try to shift right at the rev limiter is to land in a higher rpm band...MOST of the races 200+/- rpms isnt going to win/lose a race...
Stock internals stock exhaust manifolds with 74,000 miles. My shift light is set on 5,800 with stock 6,200 rev limiter.
Might move it to 6,000 when I put on Headers and Dual Exhaust, although I bet the valve springs are worn out....
