View Poll Results: which shifter
B&M
17.65%
hurst
27.36%
pro5.0
48.29%
other
6.70%
Voters: 731. You may not vote on this poll
shifters
Old Jul 24, 2006 | 01:08 AM
  #121
Domestic Demon's Avatar
So which one of the shifters listed above actually alters the internal of geometry of the shifter so that the throws are actually reduced. I understand how a shorter stick reduces the throws, but what shifter offers the shortest throws while still retaining a longer lever?
Andrew
Probably the Pro 5.0. Its got a very tight pattern, with short, precise throws. The stick is shorter than stock (its the perfect height, the shift handle just touches the top of the boot) but not so short that you can't reach gears with the seat reclined. Also, if the stick is too short, it requires too much effort to shift. I think the Pro is the best compromise between shortened stick height and shorter throws.
Old Jul 25, 2006 | 12:16 PM
  #122
Project GatTagO's Avatar
Thanks. Thats exactly the kind of information I was looking for.
Andrew
Old Jul 26, 2006 | 03:26 PM
  #123
CRL 01 SS's Avatar
Pro 5.0 w/ Lou's Short Stick here. I've driven other F-Bodys with the Hurst and B&M shifters, but the Pro 5.0 felt the best in my opinion.
Old Aug 8, 2006 | 01:00 PM
  #124
Rescue Ranger's Avatar
Originally Posted by eli_pem01
I have a pro 5.0 and its noisy as hell but I love the way it feels.
tighten the 9mm bolt in the handle. Mine was noisy as f*ck until I realized where the noise was coming from. now, its dead silent.
Old Aug 9, 2006 | 01:26 PM
  #125
chris2000ss's Avatar
I still have the stock hurst..works fine
Old Aug 9, 2006 | 02:52 PM
  #126
megawayne's Avatar
I bought the cheapest on Ebay, works fine. Exactly like the one my friend payed 100+ for.
Old Aug 17, 2006 | 12:44 PM
  #127
bastien's Avatar
I am currently using a pro 5.0 w/ a shorten pro 5.0 stick (~1 inch)
Old Aug 26, 2006 | 05:15 PM
  #128
02NHRAtransAm's Avatar
i have the fac. hurst... love it
Old Aug 27, 2006 | 07:51 PM
  #129
98 SNAKE EATER's Avatar
Power Tower + Lou's Short Stick + Hurst "H" **** =
Old Aug 27, 2006 | 08:03 PM
  #130
ssmaro's Avatar
Well I just ordered a Pro 5.0 and Lou's short throw stick. I'll tell you how much of an improvement it is when I get it installed.
Old Aug 28, 2006 | 10:33 PM
  #131
ldickson's Avatar
I love my b&m shifter.
Old Sep 7, 2006 | 10:22 PM
  #132
Black FormulaLs1's Avatar
PRO 5.0 all the way!!
Old Sep 21, 2006 | 11:38 AM
  #133
wkniffin98ss's Avatar
I have a 5.0 and it has a ton of play in it i dont know if it just needs to be adjusted or what but it is pretty bad. Is anybody else having this problem?
Old Sep 21, 2006 | 01:33 PM
  #134
grb's Avatar
grb
My new 5.0 isn't nearly as tight as the one I put in my 00 SS. POS!
Old Sep 21, 2006 | 02:30 PM
  #135
Worn ballcup perhaps?
Old Sep 21, 2006 | 02:34 PM
  #136
grb's Avatar
grb
Mine has less than 100 miles on it.
Old Sep 21, 2006 | 03:24 PM
  #137
Is that fixable or am I going to have to replace it? It only moves front to back it doesnt wobble side to side could it just need to be adjusted?
Old Sep 23, 2006 | 10:01 PM
  #138
02SOMWS6's Avatar
Make sure the 2 bolts that hold it in haven't backed out. This happen to mine once. Use lock-tite on the bolts and they will stay tight
Old Sep 26, 2006 | 01:53 PM
  #139
z34_nut's Avatar
I'm in love with my Hurst Billet Plus shifter. The timeless chrome handle and the classic black ball mounted on top. I notice alot more road noise also, but thats because the factory boot will not fit over the Hurst shifter. I left it out for now, The only advantage I see with that boot in place is noise levels.
Old Oct 9, 2006 | 10:42 PM
  #140
Joey7489's Avatar
Question
When I bought my car it had the B&M Ripper... The throws are decently long compared to my bros Cobra MGW(sp?) shifter, which is barely having to move your hand to shift from 1 to 2...
My friend bought a camaro last night and Im trying to figure out what shifter hes got. The throws are VERY short and a bit clunky. I dont know what shifter it is. I tried to get the shift **** off, but it wont unscrew. I have some pictures here if that will possibly help you determine what frikin shifter it is.. Because w/e it is, Im buying.. I dont like how long the throws are in my B&M..[p]
