launching with m6 and et streets
Old 02-24-2006 | 11:13 PM
YngBird's Avatar
Default launching with m6 and et streets
i want to buy some 255/50 16 bfg drag radials for the track.i hardly go but i cant stand spinning my tires everytime i shift.i have a 93 m6 and a stock 10 bolt.my question is whats the best rpm to launch at with a stock 10 bolt and drag radials?
thanx for the help
Old 02-24-2006 | 11:22 PM
HowellSoccer88's Avatar
verrrrrrry low...you will most likely bog but to me its worth the price of a 12 bolt. maybe 2000 or 3000 if you are feeling real brave/lucky. the worst part about this method is the 1-2 shift because you know you are going to rip that shifter back harder than ever before lol
Old 02-24-2006 | 11:29 PM
i just saw your sig...your 3.73's might take a tad bit more than the 4.10s but i wouldnt push your luck...also which are you running? the kdws or the et streets? i can tell you from experience that the kdws will be a little better on the life of the 10 bolt because for me personally they gave just a tad bit of slip (maybe a rotation) and then a tad bit in second so it relieves the rear end of a little bit of the shock. the et streets on the other hand just hooked like a bitch and showed no mercy to the rear
Old 02-24-2006 | 11:36 PM
wrencher's Avatar
wrencher
Your gonna break w/ a tire eventually.
Get a real rear, & do some 6K clutch dumps!
Old 02-25-2006 | 11:13 AM
black_z's Avatar
I dumped mine at 3500-4000 with nittos and bogged. Stock rear is holding up good, 77K miles.
Old 02-25-2006 | 11:54 AM
LS1_Unleashed's Avatar
you will do fine with those tires, for maybe 2 passes, then just say goodbye to your 10-bolt. from what ive seen/heard/read, those tires will destroy the 10-bolt if your not careful. awesome tire, crappy rear, thats all it is. goodluck with whatever you decide to do though.
Old 02-25-2006 | 08:57 PM
YngBird's Avatar
thanx.i thought slicks were hard on the rear.i thought et streets would be ok,i guess not.right now i have kdw's but i was thinking about getting the et streets.i guess i will hold off til i get a 12 bolt.i have ran my kdws at the track at 40lbs and it hopped like like ****.then i lowered my tire pressure to like 12lbs and it hooks up fine.so i keep doin whats working till i get money for a 12 bolt after the heads.or break something
Old 02-25-2006 | 09:17 PM
ctucker's Avatar
even though its working be careful because if you dont have the money for the rear when the rear goes your out of a car until you do get enough money for the rear. then you can get slicks and really have some fun
