What Is The Part # For The Ls7 Clutch Kit And Ls2 Flywheel Thru Gm?!
I call them and the places around here dont know crap about F-Bodys. If someone could get me the part numbers I need to put an LS7 Clutch in my 98 Trans am that would be great! Thanks
i dont know the part number but i would ask around before your purchase.I saw a guy last knight blow his ls7 clutch the F*#k up in his zo6 with just headers.It stopped shiffting he replace his fluid made another past 11.50 best of the night 2 more past on the 3rd one boom sparks cable fluids all over track! That sucked fast *** car sorry clutch!
Originally Posted by 98WTA
Crazy...well I am putting down around 400hp soo I just need a good clutch for 500 or less..any suggestions?
So you had to buy the LS7 Clutch and LS2 Flywheel? what did it run you? I work for Courtesy Mercedes..so I get my Employee Disount at the GM Dealerships..Plus I get it installed at the dealership for 60 bucks..not bad???
You really need to learn to use the search function of the board. There are over a dozen threads on this question. And yes, you do have to use the LS2 flywheel with the LS7 clutch. Fred Beans has some good prices.
https://ls1tech.com/forums/search.php?searchid=3489784
ls7 clutch kit---------24233650 $300.67 (New # is 24236500 $287.09)
ls2 vette flywheel----12571611 $178.00
slave clyinder and T/O bearing --------15046288 $107.45
ls1 pilot bearing------14061685 $9.53
