who else is using the Spec Super twin?
They did take care of me though, so maybe they'll do the same for you (hopefully). The only complaint I have with it is it still has a "wandering" engagement point- sometimes it will start to grab about halfway and feel like a stock clutch in it's engagement, other times it grabs all the way up like an on/off switch- kind of hard to drive it in traffic when it is different all the time lol. I honestly think the floater plate binds a bit at times making engagement vary a bit with heat and such.
Mine did that too. Sometimes it would start to grab halfway up then just quit. Most of the time it caught right at the top of the pedal though.
Joe
I drove mine a little bit yesterday.. engages at the very top of the pedal. Pedal feels very light too, very very light lol... like my stock c6 kind of light...
worried about the air gap now
Guys, I think it should be quote clear that we are willing to work with anyone that has issues here. I have done everything I can to insure that Both Joe and Jason were taken care of. If you have a problem them give call...it really is a pretty simple request. As a side note, inconsistent engagement is not the clutch. The only thing that can vary the engagement point is the hydraulics. It is not physically possible for the clutch to change its geometry. It is however very possible for air in the lines to cause the release point to be inconsistent.
Jeremy- the problem with the release (with mine at least) is NOT hydraulics. We have been through this before. I know you are not in control of everything that goes on once it leaves your door, but saying "hydraulics" every time there is a problem is an insult to my/our intelligence. If you don't recall- you told me my other issues were hydraulic from the start also, which as we well know- they were not
. The clutch will start to grab at a low point, the car will start to move, then you hit the gas lightly and it will instantly free up and not grab until the clutch is almost all the way up. This is not air in the system, I think most (some?) of us are smarter than that
When I discussed this problem with you before, I had mentioned that I felt it was the floater plate hanging up and dragging on one of the disks and you said that you had never seen that, but it was possible it was a burr on the input shaft holding one of the disks up (which would have the same effect). Well, it was not a burr, the input shaft splines were perfect, besides it now has a brand new input shaft due to a worn gear (not clutch related). It is not the pressure plate, slave, air, etc. doing this as it releases correctly, but something is dragging for a second, leading to the only other moving part that cannot be hung up on trans splines or actuated by the slave- the floater. It is as if it hangs up a bit, and grabs the disk early as the pressure plate starts to engage the disk. Once you hit the throttle and RPM's increase, it is like it "pops" free and disengages instantly- that is not air.
The car is also more difficult to get in gear running than when it's not- no, it's not air either
. Once I put it in gear, it is easy from there on, but the initial pushing it in gear is pretty hard like it has to stop the disk from dragging. I really think the floater doesn't "float" very freely- especially as things get hot and expand- it is easier to get in gear cold than hot and the pedal doesn't usually do it's half travel then break free crap until after I've been driving around a while either.
Sorry for this being so long, it is hard to describe this stuff in two words.
Joe
. When I discussed this problem with you before, I had mentioned that I felt it was the floater plate hanging up and dragging on one of the disks and you said that you had never seen that, but it was possible it was a burr on the input shaft holding one of the disks up (which would have the same effect). Well, it was not a burr, the input shaft splines were perfect, besides it now has a brand new input shaft due to a worn gear (not clutch related). It is not the pressure plate, slave, air, etc. doing this as it releases correctly, but something is dragging for a second, leading to the only other moving part that cannot be hung up on trans splines or actuated by the slave- the floater. It is as if it hangs up a bit, and grabs the disk early as the pressure plate starts to engage the disk. Once you hit the throttle and RPM's increase, it is like it "pops" free and disengages instantly- that is not air.
. Once I put it in gear, it is easy from there on, but the initial pushing it in gear is pretty hard like it has to stop the disk from dragging. I really think the floater doesn't "float" very freely- especially as things get hot and expand- it is easier to get in gear cold than hot and the pedal doesn't usually do it's half travel then break free crap until after I've been driving around a while either.Sorry for this being so long, it is hard to describe this stuff in two words.
Joe
Joe
I haven't installed my spec twin stage II in the car yet but I wonder if taking a file ( CAREFULLY) to the floater plate tabs would free up enough space so this does not happen ( if it is in fact the problem). This would also clearance enough material between the floater plate and the billet housing to account for expansion due to heat which may solve the once things have warmed up issue described. Just my .02
Joe, I wasn't insinuating that every issue was hydraulic...I was simply pointing out the fact that all to often...hydraulics are in fact the issue. I helped you in every way possible, as I did with Jason. I have not read every post in this thread, as I haven't had time, but I am unaware of you having any further issues...right? You asked about people contacting me specifcally...that is fine. For the person that had an issue with another person here, please PM me and let me know who you spoke with. Thanks!
I am not having "problems" with the clutch as in it is perfectly livable- but, the engagement does vary at times- and it is not as the pedal pumps up or anything else related to hydraulics or air, it really does it more as things heat up and I personally am 99.7% confident it is in the floater. I think it needs to be a bit looser. Now, that is where the catch is for you- if you loosen it up to address this issue, for every 5 people that notice the improvement and appreciate it, you'll have 5 more that complain it is noisier with the clutch in
. I do feel that it needs a couple thousandths more clearance between the floater tabs and pressure plate assembly so it moves a bit more freely. Even assembly/disassembly was a bit tough due to the plate fitting so tight in there, I wondered from the start if it was maybe too tight, but it wasn't a big deal compared to my other issues at the time. It isn't a major issue for me- Just adding my .02. I'm in no rush to mess with it, the car is running great and the clutch is holding fine so far. If I do anything with it, it will be during the winter when it's laid up and even then, I don't think I'll bother.
Joe
I think the biggest problem with the Spec twin disk is the over all height of the clutch. I have a spec twin disk that I am running with no issues but if I wasn't running the Mcleod bellhousing with the motor plate then I would have issues with the over all height of the clutch. For me if I didn't run the motor plate then my throw out bearing would of bottomed out and the pressure plate would be slightly depressed all the time.
Joe
I have an LS2 block but I did check my McLeod bellhousing against my stock LS1 bellhousing and they are the same height without the motor plate. The motor plate is 1/4" thick.
First time I installed it, I used the TOB supplied with the clutch, but I machined that down when trying to make the clutch fit, so now I have a new GM one in there. They both measured the same.
Joe
