GTO T-56 vs. F-Body T-56
![Unhappy](https://ls1tech.com/forums/images/icons/icon9.gif)
OK people looking for facts & opinions out there! I got a T-56 out of a 04 Goat w/18k miles on it, that I'm installing in my 67 Camaro. Hopefully I'm gonna be looking at @ 420 hp. Should I do anything to this tranny before I stick it in? Does the 04 T-56 have all the same weak points that the F-Body had (Need the drill mod, weak forks,etc.)? I've noticed that the GTO and the Vette tranny cost an additional $331(www.SixSpeedsInc.com) to get rebuilt...are they similar? And one more question, will the F-Body Master Cylinder & line work on the GTO and possibly (if I upgrade) the LS7 slave cylinder? Thanks!!
6600 rpm clutch dump of death Administrator
The GTO transmission is superior to the F-body transmission as it has triple cone synchros. The only other transmission comparable to it are the Corvette specific ones. So, you did VERY good getting a GTO transmission.
I'm not positive but I think '03 and later t56's had steel forks.
Amber and Joe at T56 can set you straight on anything you need to do or not do. As long as everything is clean, and there is not a ton of debris on the magnet, you are probably ok to go. At 420 RWHP, you should be ok for anything you want to do.
The slave cylinder is the same, and the F-body line you use should hook up to it with no issues.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
i went to the GTO tranny aswell back in Jan, i LOVE IT!!!! for my setup it works perfect w/ th 4.10 gears. still get 20mpg. daily driven.
since i drag race alot, i shift into 4th gear before the 1/8mi and pull 4th through the traps.
its alot smoother and not as notchy as the fbod t56
-good luck
brandon
-good luck
brandon
Originally Posted by GR33N GoblinM6
i thought the tail housing were slightly different, is that not true?
the only thing i had to change over was the shifter cup, (little cup that the end of the shifter fist into)
-brandon
Originally Posted by 02NBMWS6
the 5th gear is nice, but i hate the large gap between 3rd and 4th on those trannys
I hadn't heard about the later transmissions having steel shift forks. Anyone care to chime in on if this is true?
Originally Posted by IFRYRCE
I was concerned about that as well. I'm looking into swapping in a M12 T56, but the dropoff between 3rd and 4th is putting me off. I do a lot of roll racing, and I'm generally starting in third. Dropping off almost 1900 RPMs when I shift could be a problem.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
jmo
brandon
I am pretty sure the 1-2-3 ratios are lower because the car is heavier, ( I was told this by a GM mech) AND the slave is the same other than you dont have to do the drill mod with the GTO slave.
or pull the connection fitting off the Fbody slave and use a GTO connection.
If you have a junk GTO slave sitting around to get a fitting off of..otherwise I doubt you can buy just the fitting w/o buying a whole new GTO slave.
