% loss thru drivetrain?
Old Oct 11, 2007 | 09:26 PM
Moz's Avatar
Moz
Default % loss thru drivetrain?
I asked this ? in the Dyno forum.Can anyone tell me what kind of hp/tq am I giving up at the crank by dynoing on a chasis dyno with a 6-speed and a Moser 3:73 12 bolt?
Thank You for any replies
Old Oct 11, 2007 | 09:34 PM
Gordon0652's Avatar
I think its like 13-14% loss thru manual and upwards of 18-20% on autos.
Old Oct 11, 2007 | 10:08 PM
Jeremiah's Avatar
A friend of mine recently did an M6 to A4 swap on his 00 T/A. He lost a hair over 5 HP with the auto. I was surprised at the numbers, I thought it would have been a lot more.
Old Mar 13, 2013 | 06:23 PM
slow ride 02's Avatar
Does anyone know for sure? 13 -14% on a M6
Old Mar 14, 2013 | 07:29 AM
Exidous's Avatar
The A4 doesn't loose that much compared. Especially if the converter is locked and it's in 3rd.
I cannot say exactly but every car is different. I've seen people say anywhere from 8-15% for the manual. Only real way to know is an engine dyno and a chassis dyno but even then you run into dyno variance.
Old Mar 14, 2013 | 04:55 PM
8-15% huh? I was just trying to figure my flywheel horsepower to order some injectors (I am @98% now) so I guess I will 15% then?
Old Mar 14, 2013 | 07:09 PM
tsheehan's Avatar
I would be looking at the LAMDA number If your engine makes power under a full load on the dyno and you are not lean I would say you are in the spec for the injector. You got 98% full capacity as a high value in you Data. or can you watch the injector cycle as you make the dyno pull?
Old Mar 14, 2013 | 07:15 PM
Exidous's Avatar
What injectors are you running now? For most stock cube built motors the ls3 injectors are plenty. I'm at ~430rwhp and my injectors max at 65%. FI will certainly need more.
Ideally you don't want to go over 80%.
Old Mar 14, 2013 | 10:01 PM
Stock 02 28lbs & 450rwhp
Old Mar 14, 2013 | 10:03 PM
I am sorry. But I wish that I understood what you just wrote.
Old Mar 15, 2013 | 05:45 AM
Exidous's Avatar
The LS3's are plenty for 450rwhp. If you were over 500rwhp I'd suggest something bigger.
Old Mar 16, 2013 | 10:50 AM
How many pounds are LS3's? and do they fit LS1's with no mods?
Old Mar 16, 2013 | 11:05 AM
3.8redbird's Avatar
42lbs and they need adapters and possibly pig tails.
FIC carries both
Old Mar 16, 2013 | 11:11 AM
FIC carries both
Adapters and pig tails? Why would you want LS3's compaired to say some FIC 42 lbs or some F.A.S.T. one's?
Old Mar 16, 2013 | 08:15 PM
Exidous's Avatar
I got my LS3's off eBay for $120 with 1200 miles. People are selling them on there all the time.
Adapters and pigtails were needed but I still saved $100-150 over aftermarket options.
Keep in mind they are 42lb@58psi.
Old Mar 16, 2013 | 08:54 PM
3.8redbird's Avatar
Adapters are 15ish and pigtails are 12ish IIRC. I bought a set of LS3s for 90. New set of 42s from FIC would run 300+ depending on sales and whatnot.
Old Mar 16, 2013 | 10:50 PM
Are you saying 27ish for the set of 8 (pigtails & adapters) plus about 100 for the injectors?
Old Mar 17, 2013 | 03:36 AM
Exidous's Avatar
No, pigtails are 27, adapters are about 80 and 120 for the injectors.
Old Mar 17, 2013 | 07:25 AM
poltergeist 02's Avatar
you can send FIC your injectors and have them resized for around $200. cheepest and best way to go IMO.
Old Mar 23, 2013 | 11:19 AM
DemonicZ's Avatar
I've heard about 5-12% thru a manual and 9-16% thru a auto
