Weird question on ls7 clutch
I have a ls7 clutch. It was professionaly installed with the drill mod. I have about 1500 miles on it. It has been very stiff but I got used to it. Now today it is light as feather. I am little worried because the clutch pedal did stick for second today. I have never used a replaced clutch and I know that clutchs need to broke in. So has anyone else running a ls7 had this happen, is it normal? It is dark out now but I am going to do the fluid flush from the sticky in this forum, just curious if anyone else has had the symtoms at the same time.Thanks for any help.
After reading the sticky, I hope I just need to flush my trans fluid. I am thinking mabe my headers are heating up the fluid. I won't know till tomorrow when I change the fluid. Just checking with everyone to know if there is anything else it could be. I did just install my LS6 intake today again, (had to replace the oil sensor
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
Hmm i only have 150 miles on mine and it feels the same with the exception of not engaging so close to the floor quite a bit closer than my ls6.
I think i really broke it in tonight coudn't wait any longer![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I also changed master & slave and used valvoline high temp fluid and no drill mod.
So far i'm loving mine.
It was my fluid I am sure. I spent a hour and used a bottle and a 1/4 of high temp syn brake fluid. It is clear now but it was jet black. At first I did not think it would ever clear up.
