View Poll Results: Hurst, Pro 5.0, or B&M?
Multiple Choice Poll. Voters: 206. You may not vote on this poll
which shifter is better hurst,pro 5.0, or b&m
#63
I put a Pro 5.0 in my 96 SS and LOVED it.. I sold the car and bout my C5 which had a B&M Ripper in it, and i dont like it as much... Its tougher to put into gear than my Pro 5.0.. Either way they're worth the money, but id def. go with the Pro 5.0 if i were to choose.
#65
I just installed my new PRO 5.0
It shifts fine but it's really noisy!
You can tell what gear you are into just by the noise, as each gear has its particular "voice".
For those who installed a gasket between the tranny and the shifter: what thickness have you used? How much is allowed before the distance is too big?
#67
Had a Pro 5.0 with a stock stick before I even drove the car. Never had a problem with it at all. - Have no Idea what people are talkin about with the " noise " full exhaust covers that up just fine.
#69
The Pro 5.0 is a good shifter no doubt, but for daily driving it's very unique. The default installation has you cutting the rubber boot. That's already an issue that causes noise in itself. The next problem is the shifter itself tends to transmit and vibrate itself in a way that rattles. It's easily drowned out by exhaust though, but since I built a true dual setup that is louder than stock, but still quiet at cruise just a bit more on the bass side, I knew when I tried a car with one, the pro 5.0 would drive me crazy. Heck even my Hurst comp will show the same rattle but only at WOT. I know the rattle changes between 2nd and 3rd only, every other gear doesn't seem to have it which puts the hurst aftermarket short sticks right up there for me.
My issue with B&M is that their newer shifters don't have removable sticks so you don't have an option like the pro 5.0 or what hurst gives you.
#70
Do you think dirt would go in the shifter mechanism?
The stock Hurst has no boot and is placed under the big rubber boot... theoretically it should get dirt
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#71
but seriously i never noticed more noise with my pro 5.0. i guess my tranny was noisey to start with and didnt notice any more, i ran it for some time without the boot cut, didnt cut it till i changed the engine last year, still didnt notice any differance with it cut, and there wasnt any dirt in it if you want to go that route, but it did take on a little moisture. the grease that is around the top looked milky, but nothin got in the tranny, and didnt effect the working of the shifter. i love the shifter myself. im sure there is someone in your area that has one of each, just ask them if you can try the shifter for yourself and then you will know
#72
What I've done with my car is highly illegal over here, for you it would be slightly modded
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Tonight I'll install a rubber gasket between the tranny and the shifter. I'll post the result tomorrow.
To my tranny: this is a 98 car that was A4 in origin and is now M6.
No idea who owned the tranny before and if it has been abused.
I rebuilt it with the usual performance parts. It's possible than newer trannies sound different. This is a 99 Borg Warner.
#73
Pro 5.0 here, no issues for me. The 4 inch mufflex, and the whine from the S60 rear probably cover most of the noise from the shifter. It does a good job in the gear rowing department.
#74
lol : I wasnt saying that was what you should do, I am saying that I have never had the car without the pro 5.0 and didnt notice it be noisey, but I have a 6.0 cammed / headers / loudmouth 1 exhaust car with lightweight carpet. So maybe Im not the best person to ask about the level of noise it makes.
#75
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
The rubber gasket hepled a little but it's not completely rattle-free.
Mine a daily drive and I really don't like rattle / grind / bump / clickclick noises.
If it was a race car... ok
Or maybe I'm getting old!
#77
1 Post
I've had both the pro5.0 and hurst billet plus. They're basically the same. The hurst has a dust boot to keep dirt out of the mechanisim which is nice.
If I had it to do over again I'd get the McLeod shifter, they make one for 4th gen T56's now and it uses a bellville washer which doesn't wear out instead of a spring.
Whatever shifter you get, but the shifter gasket for like 12 buck off a guy on ebay who sells them. It quiets them down tremendously! No where near the rattle.
#78
i like the feel of the 5.0 Shifts are very nice. cant hit the 2-3 shift ever under WOT, but i dont think its a shifter problem. Thinking its more a clutch problem since i lose the pedal. Had the factory hurst and it had a pretty nice feel to it too.
both are good either way. have not tried the B&M
#80
I've had all three and I swear by the B&M ripper shifter, I love that I can SLAM it thru the gears and I LOVE the feel and how solid it goes into the shift gates. Not as smooth as the factory shifter but I'm okay with that. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Yes it's a bit noisy, but hey, so was the 5.0 and the Hurst(not as loud though). The extra noise doesn't bother me, it's not loud IMHO.
