Which Clutch for Stock Pedal Pressure?
Old 07-13-2003 | 07:35 PM
Unusual T/A's Avatar
Default Which Clutch for Stock Pedal Pressure?
Car is in sig and now has an 8.8 with 3.73 gears. I currently have a ram 6130/402pp combo with a mccleod adjustible master. The pedal pressure on this is tough and I want something smoother and more like the stock zo6 that came with the car. Anyone have any recommendations? Spec 2 or 3? I'm going to be launching at 5k plus at the track.
Thanks
Nick
Old 07-13-2003 | 09:57 PM
2001CamaroGuy's Avatar
Default Re: Which Clutch for Stock Pedal Pressure?
I have the spec stage 3......
I think its even lighter pressure than the stock clutch was (though they are REALLY close) and it HOLDS!!!!!!!!!!!!!
Old 07-14-2003 | 01:12 AM
What master did you use and was the spec 3 carbon or ceramic?
Old 07-15-2003 | 08:06 AM
TaTommyWS6's Avatar
You can use your stock master with no problems, which is one of the main reasons I went with a Spec III carbon.
Tommy
Old 07-15-2003 | 06:14 PM
Stick only's Avatar
We have found the McLeod master gives a harder pedal. It moves more fluid and thats going to happen...
Old 07-19-2003 | 12:43 AM
NLinnear's Avatar
My Spec Stage 3 has a slightly firmer pedal than stock.
Old 07-19-2003 | 06:00 AM
Formula 1's Avatar
Spec III here!
-Travis
Old 07-19-2003 | 07:03 AM
35th SS's Avatar
same here with the mcleod master with my twins.pedal feel is harder and also did the drill mod.
Old 07-19-2003 | 09:54 AM
TEX2KZ28's Avatar
I have the 02' master modified for adjustment with the Ram VDS and 910 disc and peddle pressure fells stock. Just replace the master and keep your RAM!
