How do I adjust my linkage
Recently I've been having problems shifting into 5th gear. I'm pretty sure it has something to do with my linkage, because when I throw the shifter fairly hard into 5th it shifts perfectly. But when I preform a more casual shift, the gears grind. I don't think it's a syncro because it doesn't matter what RPM I'm in when I shift. A hard shift gives me a perfect shift every time.
This seems to be consistent with my linkage being out of adjustment. And if so, how can I go about fixing it?
wrencher
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
All the linkage is internal to the transmission. There are no axdjustments.
Your gonna need to get into the internals of the trans & inspect it.
It could be something simple like shift fork pads or more like a syncro issue.
