t56 max power
04-06 GTO's have a GM, MM12, T-56 rated @ 400 #-ft. So, if you're making more torque & the flywheel than 400 #-ft, you are making more torque than the MM12 is designed to take. This is not to say that you can't get away w/ it for a while. Many people make more RWT (more @ the flywheel) than this while using a stock T-56, without issue.
FYI, D&D Performance makes a GM Viper T-56, rated @ 650 #-ft..
There is a guy on tech that has a mild h/c set up, 400 wrhp, gto trans with 9" with 4.11 gears, and his has been holding up to his ridiculous amounts of street races. Pewterscreamingmachine I believe is his sn...go over to the street kills section, and you can see how many god damn races he gets, and his **** is holding up fine.
