Another Hall's deal!!!
#3061
There is no drug in the world better than nitro, period.
I may be a little biased though.
I'm back from the Nationals qualifying, I got enough of a nitro fix to tide me over till October for the T/F bikes in Norwalk; if all goes well the new bike will be done and I'll be working on a team again. Nothing better than standing at the line getting hit with rubber watching a motorcycle on 96% nitro slamming out a 5 second pass, yeehaw.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#3064
#3065
The car is almost completed....a few small things to clean up and she will be rocking.
BIG THANK YOU TO NATE FOR A JOB WELL DONE....wouldn't be this far without him. I would recommend him to anyone.
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
#3068
That was me. No idea, never done that before until last night when I was infront of a ton of people. It was acting like it was running too rich and flooding... then would run fine until I would let it idlefor more than 30 secs...and then start dying again. I unhooked the battery for 10 mins and it has run fine since.
#3071
Did you hear about his run at nationals on Friday. They broke a rocker at 1000' boost spiked wiped out the cam and spun two mains. I feel so bad for them. I give them so much credit though. They go out break **** and dont ever quit. Soon they will pervail and get some wins.
#3072
#3073
It's "speed density" tune, NO maf on car? Hey Blake, I have an issue with the #1 fuel injector that it keeps leaking on the fuel rails you sold to scott massey? Did you have any issues with this?
#3074
Yea I have no MAF, turns out the problem still exists. It comes and goes, it will start to stumble at idle and when I give it gas it will die. Then I can let it sit for 2 mins and it will start right up and seems to drive fine. I'm assuming its a tuning issue but I have no idea, kinda acts like its not getting fuel
#3075
Why the **** did Massey replace the stock fuel rails on the Camaro? He isnt needing thekind of fuel supply that requires an aftermarket rail system??????? More aftermarket **** to go wrong!!!!
#3076
Last night was dead for the most part. I was expecting to see a bigger crowd than that. I heard Friday was even more dead. (It could have something to do that I did see a few fast cars come up, look at all the Subaru's parked up there, and left).
Hopefully more people will be out tonight. Who all is going to be up?
#3078
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
No, I didn't have any issues with the injectors on those rails. Only problem I ever had was a cut in the o-ring on number 7, but that was because I nicked it removing it from my old rails. You may try swapping the way that that brackets that hold that rail to the intake are oriented to pull the rail a little closer to the intake; I hadn't
tried them with a FAST before, so I installed them the same way they were on my LS1 intake; perhaps the FAST needs them oriented the other way (their aluminum intake has them in that manner).
I did talk to Pro-Products and they stated they've tested them with FAST intakes and didn't have any issues, so it certainly should be workable.
Kyle, if you want to borrow my tuner, it can scan any car, if it's something obvious you can probably see it.
#3079
My cheap, inexpensive, bling-only mod hasn't been quite the bargain I thought it would be.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#3080
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
seemed like a fairly decent night, missing a few of the usuals, I was expecting ricky martin to be out.
