Another Hall's deal!!!
#3504
1-260-385-7227
I'll take hers also any time.....
Luke i need to borrow your tools....hahaha Yea so the tow truck dropped the car off last night at 4am and by 7 am I had it down to the water pump and timing cover. Then I went to bed at 7:30 and woke back up at 10 and started pulling the rest down.. Sean is a really nice guy, JPH and I will get that bad boy back going soon for him
![Punch](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_punch.gif)
#3506
sorry, for the thread hijack. I have been having a nasty grinding sound coming from the bellhousing of my 06 equinox. i was able to figure out what it was just a few minutes ago. I found a bolt flopping around inside of there. It looks like a 10 mm head, about an inch 1/2 long and 8x1.0 thread. Does anybody have any idea what this could have come out of? Anybody have a breakdown of whats bolt sizes are on the flexplate to crank? all the torque converters are there and torqued. maybe on the front of the trans?
Nasty, if you need to check out the pistons on the vette. I have a digital borescope. it has an rca cable adapter to record onto, or you can hook it up directly to a tv and see how it looks inside. Sunday afternoon i checked out a friends pistons and cylinderwalls with it. Its not mine, but i could stop by with it and check out how bad the pistons are in the vette. Give me a call, if you want to take a look. 615-4337
![](http://i216.photobucket.com/albums/cc183/lucasAugustyniak/100_2562.jpg)
![](http://i216.photobucket.com/albums/cc183/lucasAugustyniak/100_2564.jpg)
![](http://i216.photobucket.com/albums/cc183/lucasAugustyniak/100_2565.jpg)
#3507
Geez I should be a watch model ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I saw the carnage first hand...kinda brought back memories of my motor prior to the first rebuild. Sorry to see it happen...Joe and Nate will get it fixed up and on the road again.
On a side note, I should be getting my new starter tomorrow and then be able to fire my baby for the first time in a long while....cross your fingers!!
#3508
Nasty, if you need to check out the pistons. I have a digital borescope. it has an rca cable adapter to record onto. Sunday afternoon i checked out a friends pistons and cylinderwalls with it. Its not mine, but i could stop by with it and check out how bad the pistons are in the vette. Give me a call, if you want to take a look. 615-4337
#3509
![Popcorn](https://ls1tech.com/forums/images/smilies/popcorn.gif)
#3511
This is mostly for Ramone, as he hadn't seen it yet, but here's the conclusion of the TT Vette and the Z;
http://videos.streetfire.net/video/S...win_169566.htm
http://www.youtube.com/watch?v=VnDQlJ6QaoU
there's a cute little Bear's reference in there for ya too beasty.
#3512
#3517
Wow Sean, you killed it good.
At least you've got some good guys here to get it taken care of for you.
Luke,
Converter and flexplate bolts should have a 15mm (or 17 mm) head on them, if that's a 10 mm head it shouldn't be that. The flexplate bolts (at least on my '98, 01, and '03 engines) have a concave face and are very shallow on the head. My stock converter bolts were similar, though I can't remember if they were 15 or 17 mm, I know they weren't 10 mm (again, this was on my car).
I concur with a rear cover bolt, those are 10 mm head, around 1" total length (including the head) and I believe an M8x1.0 thread.
Luke,
