Another Hall's deal!!!
Running the stock tpi small cap HEI distributor w/msd blaster coil p/n 8207.
I would pull the wires and cap off, check the contacts on the underside of the cap, check/replace the module, and check the coil too....lots of parts that could be causing the breakup...Are the wires fairly new? Check to see if they are "leaking" spark at night when its dead dark out...
Installed the wires two years ago. Inspected them before I installed them on this setup and they looked good. They really don't come anywhere near the exhaust to be burnt. I also wouldn't think it would drop off like that if it was "leaking"
I know some of you guys are only roll racers, LOSERS! Those of you who are knowledgeable on suspension geometry, instant roll center, spring rates, shock and strut settings and rear suspension information. Would you happen to have any bookmarks or links that you can point me towards. I read some information earlier today that has me somewhat confused. I'd really like to cross reference it. I actually wouldn't mind if the information you are directing me towards deals with a 3link type suspension, but anything will work. Whatever you've got, i'll check out. Books at the library are fine too.
Thanks guys!
Thanks guys!
Luke I have this book if you want to borrow it. It has some good information that deals with 3 & 4 link plus some other styles.
http://www.amazon.com/Build-Winning-.../dp/1557884625
I think I've got a few sites about that, though more of them are based on road race than drag race, still might be relevant though. I'll dig through them for ya.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Here are some dates left that Muncie will still be doing Test&Tunes on before closing for the season if your garage queens and show cars ever want to make it out to the track this season:![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Wed. Sept. 30th (normal test/tune)
Fri. Oct. 2nd (track rental day?/fast&furious friday nite)
Wed. Oct. 7th (normal test/tune)
Wed. Oct. 14th (normal test/tune)
Wed. Oct. 21st (normal test/tune)
Wed. Oct. 28th (normal test/tune)
*** LAST WEDENSDAY ***
Goodluck people!!
Goodluck people!!
Goodluck people!!
Goodluck people!!
Thanks guys!
Thanks guys!
I could break the rear end too, I'm just rocking out these 275 40 17's right now, and there isn't enough bite in them to hurt anything. just wait until my car is on real sticky tires, that will put it to the test.
I dont know if many of you would care but i went out and rallycrossed for the first time today. Here are some pics. the track is next is part of the motoplex in laotto. RPMCHALLENGEUSA.COM
BLAKE....YOU MUST BRING THE WIFEYS CAR HERE....NOW.
![](http://i292.photobucket.com/albums/mm8/stellhornata/P1010454.jpg)
![](http://i292.photobucket.com/albums/mm8/stellhornata/P1010453.jpg)
![](http://i292.photobucket.com/albums/mm8/stellhornata/P1010452.jpg)
![](http://i292.photobucket.com/albums/mm8/stellhornata/P1010448.jpg)
![](http://i292.photobucket.com/albums/mm8/stellhornata/P1010445.jpg)
![](http://i292.photobucket.com/albums/mm8/stellhornata/P1010443.jpg)
![](http://i292.photobucket.com/albums/mm8/stellhornata/P1010442.jpg)
![](http://i292.photobucket.com/albums/mm8/stellhornata/P1010440.jpg)
![](http://i292.photobucket.com/albums/mm8/stellhornata/P1010441.jpg)
![](http://i292.photobucket.com/albums/mm8/stellhornata/P1010438.jpg)
B) Where were you guys a month ago when starbright was running his mouth and I had a half dozen cars lined up for you guys.
C) Try not to roll around with a Civic hatch / Space shuttle replica. You lose any and all credibility... seriously
