Kooks Dual Exhaust
Good ear. Yes I've been fighting with it a little while. Needing to get it back to the tuner. I pulled out my crank and cam position sensors and replaced them. Found small amounts of metal on the cam sensor. After I replaced them I did an oil change and didn't find anything alarming but the car ran a lot better. Since then it has started acting up again. I'll probably pull the cam sensor again and look it over. I may need to relearn the two sensors again though.
I hope you can chase the problem down! Sounds great!
Cheers
Cheers
