rear gears and ABS
rear gears and ABS
I just got done installing after market gears in a 2002 z-28. Now the brakes seem to pulseate and the ABS light is on. Anyone know my problem? Thanks!
Moderator
ABS doesn't care about gear ratio, the ring
reluctor or the axle-end reluctors for 4-ch
all turn at wheel speed.
If you had a 3-channel (no ASR) car and you
swapped in a new carrier without the reluctor
ring, you are hosed. These cars have one ABS
pickup into the pumpkin.
If it's a 4-channel car, check that the ABS
pickups are connected back up and not out
of position relative to the chopper wheels
at the hubs.
at the hubs.
1 Post
You need to tune the PCM so it knows what gears you have. It will do that until you get it tuned. When I put 410's in, it was horrible. Low traction light came on at every stoplight and my ABS activated
