How much for a granny fluid change?
I only ask because I don't know how to do it myself. Is it an easy diy? If not how much should I expect to pay for just a change of fluid? And how much for a flush? Thanks guys
I don't know about changing it, but I'm sure as **** not puttin in my Dip Stick to check it..
Tranny Fluid and Filter change isn't that bad. It can be a little messy if you aren't patient with it. It's good to un-bolt the Pan and leave a bolt in each corner, then take one out and loosen the other, and break the Seal with a Flat-head screwdriver, and let it come out.
