lq9 durability......?
Old 06-30-2009 | 02:45 PM
lsx3rdgen's Avatar
Default lq9 durability......?
I am looking at getting an lq9 block and selling my ls1 short block. i want to know how strong the 6.0L blocks are. I am planning on running a twin turbo set up and do not want to put money into building an engine only to have the block break. Also what is a ls6 intake off a 02 camaro ss worth with injectors and rails. THANK YOU FOR THE HELP
Old 06-30-2009 | 02:48 PM
406malibu's Avatar
the block itself should be good to 1000 + hp. any more and Id put a girdle on there. The ls6 intake has been proven to over 800 hp for FI applications. I am pretty sure you will have to get some aftermarket rails to flow enough fuel, and I KNOW you will need bigger injectors. I'm only a bolt on car and my injectors are maxed out. You'll probably need some 60 lb + injectors. You are still going to need to upgrade the rotating assembly though.
Old 06-30-2009 | 03:12 PM
lsx3rdgen's Avatar
i am going to buy a edelbrock proflow intake with edelbrock rails. i just want to know how much i can sell my intake for. i am boosting it so i want to make sure that every thing holds up. it is also in a 84 camaro so clearence is not an problem.
Old 06-30-2009 | 03:16 PM
deelong4002's Avatar
From everything i Read the 6.0 iron blocks are good to 1000hp. I believe one guy is getting that with the stock crank, but imo its not worth worrying about it. Forge the rotating assembly lower the compression and run 700rwhp without a problem.
Old 06-30-2009 | 03:21 PM
lsx3rdgen's Avatar
thanks for the help! Why wont it let me post on the part classifieds.
Old 06-30-2009 | 03:23 PM
devildog's Avatar
You need 50 posts bro.
Peep the 1st line...
https://ls1tech.com/forums/lsx-parts...-3-4-09-a.html
Old 06-30-2009 | 07:03 PM
406malibu's Avatar
^^^ or 6 months of membership. (do not spam to get those 50 posts because a mod will reset you to 0, or ban you) the ls6 intake should bring about $300.
Old 06-30-2009 | 11:34 PM
NBMZ/28's Avatar
That iron block is great for boosted application. It comes with extra weight but well worth it in trade for durability.
Old 06-30-2009 | 11:43 PM
lsx3rdgen's Avatar
I am not worried about the 50 post. I am just starting this project so there is a lot of questions i have. I just dont want to put all this money into an engine and have it blow up.
at what power range does the ls1 block start to become a concern with or with out a main girdle.
Old 07-01-2009 | 01:58 AM
DVS99TRANS's Avatar
If you forge the LS1 motor, it can handle quite a bit for sure. There are some FI guys that have made 800whp with a forged LS1 block on the stock crank without it even flexing. What power are you figuring you are going to want? If you are thinking in the 1000+whp region then I would suggest moving to a LQ9 minimal or possibly even an LSX block. If your only looking to do it once and last a VERY long time, then that is the route that I would suggest. The LSX is a bit pricey, but well worth the insurance. Anything below say 850whp should be tame enough for the LS1 block, but I would forge the snot out of it with ARP hardware/studs on everything. A girdle is only needed if your going to do a max effort 1200+whp motor, if that is what you are planning. Depends on what your goals are...
I'm not expert though, I would contact or call a sponsor if I where you>>>
Most likley LME, Virgina Speed, or HKE would be you best bets. They are some of the top engine builders for LS series motors that have made motors day in and out for applications like this. They would know better than anyone just about, and could point you easily in the right direction.
Mike
Old 07-01-2009 | 02:19 AM
Reject's Avatar
you need to join us in the FI section...
the block isnt the problem, its the heads lifting thats the problem. you never even told us how much hp your wanting...
also is this a strip car or what.... we need more info.
Old 07-01-2009 | 08:49 AM
demonpixel's Avatar
Plenty of people run twin turbo setups on LS1s also. That said, the iron block would be able to handle more of a beating, since aluminum is a softer metal.
Old 07-01-2009 | 01:18 PM
lsx3rdgen's Avatar
I am planing about 900whp. I am looking at a rotating assembley from texas speed, with a dragon slayer crank, compstar rods and weisco -32cc pistions, and i will have arp studs in the heads. it will be mostly a strip car that is street drive once and a while.
Quick Reply: lq9 durability......?
