Question!!! Is this normal???
When crusing in 3rd or 4th gear going anywhere from 50mph - 70mph, when you floor it....should the car accelerate from the gear it's in, or downshift to the lowest gear the computer will allow it to based on speed and rpms??
My car has been not downshifting when i floor it anywhere above 50mph.....just wanted to ask if this is normal before I throw more parts at it...
Here is a list of the parts I have replaced in the process of addressing check engine lights and trying to figure out this downshifting problem :
Throttle Position Sensor - AC DELCO
Mass Air Flow Sensor - AC DELCO
Oxygen Sensor - Drivers Side(pre-cat) AFS-98 - AC DELCO
The car seems to run a little better after each part and now I have NO CHECK ENGINE LIGHTS.....but it still seems not 100%
PLEASE HELP!!!!!!
Like 75%. If it does it there but not at full open,
suspect a TPS overvoltage causing short-shifting
behavior.
Measure TPS voltage at WOT (engine off, key on)
and if it's over 4.7V you have to fix that.
"Bump stop mod" is commonly done and can be
overdone, causing this.
when i installed the TPS, i just bolted it on....was i supposed to make any adjustments??
how do i check the voltage?? I'm assuming I need to go buy a meter LOL....then what??
Thanks in advance for you time!!!!
With a 3.23 geared A4 (that's the stock gears for your SS) you should be downshifting to 2nd gear at up to 70mph.
If you can get your hands on a decent scanner, you can also verifiy what gear is commaned when you punch it at 60, 70, etc.
Are you sure the car has stock gears and/or stock tuning?
I'm not sure my gear is stock because I bought the car used....is there a way I can tell based on rpm/mph?
At 70mph I think the RPM's are right at 2k in overdrive(4th gear).
thanks
The bump stop mod alone will never be worth major power. On the other hand, if your throttle cable is far out of adjustment, removing the slack can certainly be worth some power if you weren't even seeing WOT values with the pedal floored.
Is 3.9v even seen as WOT by the PCM? I thought it was 4.0v and above.
Now with it at 100.1%, it's like a whole new car....
So, yes, getting 100% throttle finally DOES light up the tires in every gear...Like others said 3.9v was way to low to get kick down from 4th to 3rd, I was never really seeing full throttle. It's also much easier to get throttle from a stop/roll.
I found:
Throttle cable was too long (3.9v WOT from the pedal inside, tightened that up)
TPS read ~4.3 from the TB itself (ground the stop down until reaching 4.65v)
Not sure what the PCM value was, but I only saw 3.9v if I stood on the pedal from outside the car and PUSHED it into the carpet. Certainly a simple and valuable fix for me either way.
