shaking and change of tone with exhaust!
i was out the other night raced a couple times with the 150 shot cars tuned, gears, stall, cam,lts, ls6 intake, and true duals after making one last run i decided to call it a night so i was heading home and my car sounded a little diff not thinking anything of it i keep going when i went under a bridge i could really tell. then i came to a light and started to stop and my car felt like it had a left to right shake thought it was a flat but no luck there i gave it some gas when the light turned green it kinda cut out just a little and shook also while taking off thats when i really heard the exhaust it got alot deeper a little louder and alot more popping in it any ideas?
ya boost performance did my tune they r very good with there work .. My oil pressure and all gauges inside r all exactly the same i just have that mis and that misfire is causing they chang of exhaust tone
Are you throwing a code? Is your SES light flashing? What kind of n2o setup are you running? (wet/dry)... Sounds like it could be your MAF, and sometimes it wont throw a code. What will happen is the car will rev up just fine, but off idle it almost seems like its missing and youll have to get on the gas and then the car will just jump...
i have a code but it threw one for emissions but im going to get it checked out today and my security light has been on for awhile maybe a week before this happened
well no luck so far i got the codes it pulled and was just an emissions code generaly cause i have no cats... im stumped the exhaust is alot quiter than it was it my first post i said it got louder but theres no way it got alot quieter for sure
If that helps you can look at it yourself, the safety brace is located under the car nearly dead in the middle. It has two dips in it, a small hole and sits directly where the exhaust goes into the duals. I have the SLP center mount. So I am not sure if the mounting is the same.
I hope that helps, highly doubtful but it takes you 32 seconds to check and it is worth it.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
I'm running with LT's but have hi-flow cats. Turned off most emissions but left a few HO2S or O2 sensor codes on. Sometimes, as far as some other vehicles, O2 sensors will throw a code saying ur running too lean or too rich. Of course, not 100% on the LS1's. Could be DTC code P1133 saying something or could just simply be be showing there is a misfire ... keep us updated on what code was thrown.
