leaking after mobile 1
I just bought a 2000 z28 it has 117,000 on it and i put mobile 1 in it and now the rear main or i think its the rear main is leaking like a bitch.. Has anyone every had this problem? im gona drain the mobile one out and put convential back in it
1 Post
Synthetic oil has better solvency. Any leaks or potential leaks that may be masked by crud can be initiated/greatened by the synthetic washing away the crud. It also has a way of finding its way through a gasket that didn't cause problems with conventional. But not because it's thinner. 30wt is 30wt, and they fall within an accepted viscosity range for 30wts.
If the leak is too large for comfort you can go back to conventional. It may not cure the problem immediately but it will eventually fade. Been there, done that. Sometimes the problem goes away fairly quickly, some times it won't.
Yeah, as mentioned, switching from conventional to synthetic can cause leaks on a higher mileage engine. The seals actually can swell up from conventional oil, using synthetic takes this away and you can be left with leaks.
Switching back to conventional will probably stop the leaks.
I agree with the others.
For people who unsure what to use and have high milage cars... keep with what your using. So many people get pressured into the synthetic oils when its not ALWAYS the best idea. Im not arguing synthetic vs conventional, but for higher milage cars that have always been run on conventional you will get problems like this.
I hope switching back fixes it for ya! But id be ready to replace the rear main.
