t-rex cam v.2 how much hp? added..
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
hey guys i just bought the t-rex v.2 cam set from thunder raceing. and was wondering if you could give me a round about estament of hp and tourq i could expect from this set up....iv got a 04 6.0 in a 2000 camaro ls6 intake stock injecters long tube headers 410 gears 3800 stall 400 turbo trany under drive pully also. any tips of what i need also would b greatly appresheated guys thanks again...
Internet Mechanic
Yes, Flycutting is recommended, or at least PTV clearence double checked. Get to Patriot Dual Gold Springs w/ Ti retainers. The car may need more stall, most likely.
As for HP #'s, you got a auto which is a dyno pig. But go to the Dyno Section and Search, you will find a answer.
thanks guys i really didnt know if i would have to notch the pistons. thatll save me some problems in the future lol. and im looking for some injectors if yall know anyone with some for sale.
I run the trex cam, full bolt ons through a 4000 stalled 4l65. The only time I dynoed was to try and see what was wrong with my car. So come to find out I put down 365 on 7 cylinders. Even through the auto I think you'll see 390-405. Dyno numbers don't mean **** though, its how it runs. Sounds awesome as well. Here's mine.
http://www.youtube.com/watch?v=SCrlm...e_gdata_player
you will have valve clearance to anything up to a .650 lift on stock heads. My buddy with a formula ran the MS4 cam .649 lift cam with his stock heads and it rolled out, cam only ran 11.40s 6 speed car. HP numbers through an auto id expect anywhere from 50-60whp gain
awesome guys thanks for the tips and ill b installing the cam set this weekend when i get home from offshore. ill b sure to get it dyno'd n have the numbers posted n let yall know how it go's
Yes, Fly cutting is recommended, or at least PTV Clarence double checked. Get to Patriot Dual Gold Springs w/ Ti retainers. The car may need more stall, most likely.
"ssperformance" thanks for tha heads up bc i was going to turn 7000rpm n i thought that might of ben close to the limit...thanks again everyone for the tips. o btw the car alredy went "11.80@ 105 & 1.5 60ft" ran out of rpm b4 i could pass the traps
so i know the car has alot of potential... and its a stock lq4 motor.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Edit- didn't see the you ran out of rpm part.
if the timing gears dots are not lined up ,or the slack of a used chain.was the car tuned,and what injectors where used?what size slick or dr was used?mite need a taller tire.
