grinding off the throttle body
ive read the threads about making the mod to reduce the slack out of the throttle body, thus opening it up 100%
today i had my car EFI tuned and it showed my tb only opened up 75% at wot. now can i grind off that nub on the tb allowing it to open the valve 100%
![Angel](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_angel.gif)
please use caution to avoid removing to much material.......check frequently to avoid this problem..a dremel tool or file works best.........have a blessed week.....captain jim
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
First off figure out if it's the throttle body at all. Work the
cable cam by hand and see what your max TPS volts are.
And measure the blade position across the face, more
importantly. That wants dead center. If you grind the
stop it should be based on that, alone.
I've seen cars that would only draw to ~80% because the
gas pedal had not enough draw. That wants a bench vise
and a piece of pipe.
i was monitoring the TB through EFI Live. anyway, i found out the problem was i replaced my throttle cabel recently and the dealership gave me teh one with traction control. i have almost 2 inches of play in my pedal
