Cam and heads for NA LS1
I am planning to add a cam and heads to a NA automatic LS1. My goal is 350-400RWHP. I am looking at the TSP 228R cam and several heads. But, I would like to stay on a budget. The options for heads would include keeping the 241s and upgrading the springs (cam package with springs), used assembled 243s, PRC stage 1, PRC 5.3s, PRC stage 2.5, PRC 237s. The sky is the limit on heads. So, I wanted to get input before shelling out $$$ for potted heads. I am considering buying used assembled 243s ($400ish) and the cam ($360ish). But, I noticed the 5.3s along with the cam are $1700 assembled with upgraded springs. I am favoring the cam and used 243s (unported) mainly because of price. Hopefully, I would not need upgraded springs which would cut into the savings. I am not familiar with the 5.3s. Are they the right fit for this application (naturally aspirated)? How would they flow in comparison to the unported 243s and stock 241s? Any suggestions with the budget in mind? It just seams like you can always spend more money on better heads (AFRs, etc). But, I am not out to break any records. I just want to wake the LS1 up a little. Thank you in advance!
get the best head you can afford.the PRC heads are good head for the money.I feel the 5.3 2.5 head is a good deal with big valves and good springs.it is a good street/strip head not too big at 220cc.a stock 243 head flows about 248 cfm at .600. a stock 243 head will net you 15 rwhp over 241s.what size stall do you have?
I bought a cam package from thunder racing, 230/224 111lsa, plus springs and rods. Car made 394 hp and 404 tq on dyno after being tuned. Only other thing done to the car is long tubes. It think the package deal was like $599.
I plan to use a Yank SS 3200 stall and the true goal is closer to 400 RWHP with good drivability (daily driver). I decided to pull the trigger on the stock (unported) assembled 243's (eBay $430). They have Vette valves and springs. Should I replace the springs? I could get a cam package with the TSP 228R that includes fresh springs and hardened pushrods. The TSP cam package that includes the PRC double springs is $700, while the package with the Comp Cams single beehive springs is $600. Are the double springs worth the extra $100 with this set-up? Do I also need new lifters? Things are starting to add up (430+700=$1130). Is the TSP 228R cam a good match for the stock (unported) 243's? All of the other supporting mods are in place (LID, MAF, ported TB, LS6 intake, 1 3/4" Kooks headers, Off road Y-pipe, Flowmaster, and of course a DYNO TUNE after the installation).
![GTFO](https://ls1tech.com/forums/images/smilies/gtfoslap.gif)
https://ls1tech.com/forums/new-ls1-o...ste-money.html
Cam only will reach your power goals. If your going to buy heads, save and get some decent ones. Patriot and Absolute Speed have assembled heads for around 1000 or you can get them used for cheaper.
