LS6 intake
LS6 intake
Is there any way to tell if an ls1 car already has a Ls6 intake on it already without taking of the intake?I just bought an 98 TA and other popular bolt on mods are already done.Someone painted the intake an I was wondering if it is an ls6 ?How can I tell while its installed?
Very easy, LS6 intake either won't have EGR, which is that tube that runs from the passenger side manifold to behind the TB, or that tube will be modified with a compression fitting behind the TB, the SLP `98-00 LS6 version. The stock EGR has a flang that has a single screw holding it, the SLP LS6 intake for those year models has what looks like a large brass nut that the EGR hose runs through that then screws on to a fitting behind the TB.
Take a pic and we can tell you for sure.
Best way to tell is to get the part number. Can't really go by the EGR fitting because early F bodies had EGR on the LS1 intake but SLP made intakes that were LS6 with the EGR fitting. On the flip side 01-02 F bodies had no EGR and were LS6 intakes, but early C5 corvettes did not have EGR and were still LS1 intakes. I remember people trying to pass early C5 LS1 intakes as LS6 intakes claiming they were LS6 because they didn't have EGR. So the best way to be 100% sure is to get the part number
i cant believe the confidence lacking in this thread. i'm an ls1 noob and i know the answer (at least i hope i do, or i might actually have an ls1 intake instead of an ls6).
look here dude. http://cgi.ebay.com/ebaymotors/LS6-I...Q5fAccessories
in one of the pictures you'll see the part number that should be on every ls6 intake. it's not very difficult.
dude, how old are you? are you new to forums in general? are you autistic?
look what happens when i enter "gm 12560688" into google
http://www.google.com/search?hl=en&s...96l449l0.3l3l0
as im sure you still havent figured it out, you have an LS1 intake.
