Best bang for the buck...head/cam combo etc.
I'm fairly new to the ls stuff but would love to get opinions...car is a bone stock 99 z28 a4 with 153000 miles motor is very tight and don't use a drop of oil.The tranny is a transgo beefed up 4l60e with a shiftkit with 7000 miles on it,I'm looking to make good power on a budget, maybe around 420-450 rwhp range with true duals and running mid 7's in the 1/8th.Any help would be greatly appreciated thanks.
Best head/cam deal IMO is the PRC stage 1 ls6 head/cam kit combo from TSP. By the time you buy some heads used and send them off to AI, you can get an aftermarket cast brand new with comparable flow. Other than the stall you also need to be thinking about your rear end...a 10 bolt with 153k won't last long with 415+hp with any traction at all.
Thanks for the advice fellows, I think I'm going with fully ported and polished 243's and a custom grind cam.Yes I'm def going with a moser 12 bolt, the rearend in it now believe it or not doesent whine a bit but it's a 273 gear in it now going with 373' putting more load on it would def make it act up.Plus I've seen way too many 10 bolts snap in two, even by a mild 360rwhp car lol...
Put a girdle on the rear and weld your axle tubes. No need for 12 bolt. Id get a truck pan for your tranny and a cooler. Should be fine for a while.
PRC stage 1 heads are the cheapest and work well but may not meet your RWHP goals. You will need a more aggressive head. I would get a custom cam and 243/799 226cc heads from AI(shop Ebay for some cheap 799 cores-they pop up for about 250-350 for your heads). I have seen a lot of Comp Cam failures and cams way off from them lately and AI unlike most vendors doesn't use Comp cams. Make sure to factor in all of your supporting mods too(head bolts,valve springs,timing chain,new oil pump etc)
How fast do you want the car to be?
I'd like to be running mid 11's in the 1/4 that would be great! I want to be keeping it somewhat streetable drive it on Sundays and taking the gal out to eat on a Saturday night.Drive it to the track and make 4-5 passes and drive it home with no worries about floating a valve,and sacrificing streetability. Keep all the interior like it is no cage just a killer budgetable combo.What stall would recommend?And I have seen some 799 headed cars run like a champ!Yesterday I went to the strip they were holding a street car race the outlaw civil wars @ rockingham there was a black ss running 799 heads with an ls2 intake 90mm throttle body, and he was flying!With of course the help of an lq9 and 76mm turbo, there potential is def there...so y'all think 799 heads are the way to go over 243's?And as far as the rearend welding up the axle tubes and putting a girdle on the rear would that still hold up under the shock when it hooks hard...I priced 12 bolts and they are very outrageous! Seems if a girdle and welding up the axles hold up sure beats the hell outta paying 3000 for a 12 bolt.Every opinion helps and I really appreciate yalls time!!!
You don't need heads for mid 11s on an auto.
799/243 are basically the same exact heads and when ported this is no difference. 799s are usually cheaper because people don't realize that
I run a ten bolt with heads cam and sixtys in the low 1.6s and high 1.5s. You will be fine.
the right stall and a mild cam with some suspension parts will get you 11s.also look at vengeance racing for good combos.a tsp st ls6 head with the right cam will get you 450+ rwhp.
LS1Tech Premium Sponsor
For you application, and the most power possible, our PRC 227cc cylinder heads with our MS4 camshaft, combined with at least a 3600 converter would easily get you to those goals. If budget is a concern, we can still get there, or if not really close with our Stage 2.5 LS6s and the MS4 camshaft with the same 3600 converter. Here are two links to our website, feel free to call with any questions!
PRC 227cc Heads and Camshaft Package:
http://www.texas-speed.com/p-1168-pr...m-package.aspx
PRC 2.5 LS6 Heads and Camshaft Package:
http://www.texas-speed.com/p-1161-pr...m-package.aspx
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
I almost forgot to mention that setup with our As-cast 225cc cylinder heads, which would be a great option for an aftermarket casting but still be easy on the budget.
http://www.texas-speed.com/p-3961-pr...m-package.aspx
__________________
Sure can, making it easier for a budget swap!
__________________
The As-Cast has cast runners verse cnc'd runners which in turn cuts cost down and allows us to sell them at a cheaper price. Same concept as the Trick Flow As-Cast 220s. An awesome way to go if your looking for a cylinder head that will net some great gains, but not hit the wallet as hard as the more expensive CNC'd aftermarket castings.
