Stock cats vs high flow cats
I have 1998 z28 with normal cats on my car and I'm looking to upgrade to some spintech high flow cats, but is it worth the cost for the gains?
LS1Tech Administrator
Received 1,687 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Is the car completely stock otherwise?
If so, the gain would be marginal at best and not worth the cost IMO. Even complete cat delete on an otherwise stock exhaust manifold/stock engine car isn't going to provide big gains. So I wouldn't expect much at all from a "hi-flow" cat swap unless yours are clogged.
To give you an idea of numbers, i have 2 magnaflow hi flow 3inch cats, texas speed 1 3/4 longtubes with magnaflow catback and lid and got 310 whp on my 98. I doubt you would get more than a couple of hp unless you get into heads and cam.
IMHO dont even bother....if you do not live in a place that has inspections just save up for some long tubes or spend the money else where... the money spent on "high flow" cats is not worth the gain that you will get...it will be marginal at best. Even if you went with a cat less y pipe with the factory exhaust manifolds you wouldnt get much of a gain...longtube headers is where its at.
