Belt Chirp Help Please
I have a 2000 camaro z28, and for a while now ive had a belt chirp. started with a new belt then moved on to the ps pump and alt, and then the belt tensioner and today i did the water pump. yet the thing still chirps away. pull the belt and ran the car with only the accessory drive and no chirp. the idler ive played with it but seems to feel almost new. i bought this car back in august. i was reading up on a post where someone back in 2012 had the same problem and someone recommended to look at a recall gm had on the bracket for the alt/idler. any ideas? i love this car but id love it more if i didnt have a chirp.
BULLETIN NUMBER:
00-06-01-008
SECTION:
06 - Engine/Propulsion System
DATE:
March 2000
TECHNICAL
SUBJECT:
Accessory Drive Belt Squeak/Chirp Noise (Install New Double Row Idler Pulley, Generator Bracket and Serpentine Belt)
MODELS:
1998-2000 Chevrolet Camaro
1998-2000 Pontiac Firebird
Built Prior to VIN Breakpoint Y2107225 with 5.7L V8 Engine (VIN G - RPO LS1)
CONDITION
Some customers may comment on a squeak/chirp noise coming from the accessory drive serpentine belt. The noise will be most noticeable at idle and low engine speeds.
CAUSE
The serpentine belt squeak/chirp noise may be caused by misalignment between the idler pulley and crankshaft pulley. A slight rocking motion of the idler pulley causes the misalignment, which results in noise.
CORRECTION
To correct this condition on vehicles built prior to the above VIN breakpoint, instal the new generator bracket, double row idler pulley and serpentine belt following Service Manual procedures.
00-06-01-008
SECTION:
DATE:
March 2000
TECHNICAL
SUBJECT:
MODELS:
CONDITION
CAUSE
CORRECTION
LS1Tech Administrator
Received 1,687 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Well the bulletin only applies to models built in mid-'00 and before. My '02 car had chirping issues too, until I replaced both idlers (A/C and Main) and both tensioner pullies (A/C and Main).
If your VIN doesn't fall within the bulletin range, then you already have the new bracket and new style pulley, therefore it wouldn't help you to change it again.
If you haven't done the idler and/or tensionser pulley on the belt system that's making the noise, then I'd start with that.
I had the same problem way back in the day, and like you I swapped a bunch of stuff to fix it but nothing worked. The only thing that eventually fixed my chirping problem was a gatorback belt.
i just dont understand it.... belt or pulley? lol i started my car today a little bit ago and it was a little bit warm out and there was barely a chirp.. still there just not as bad...
I did Gates for my belts, both tensioner assemblies and idler pulleys from Rockauto. Just figured one was chirping so did them all. A few months later my water pump went and when I removed it the bearing play was horrible! So don't rule that out either
i was looking at gates. my waterpump had a little bit of play but once i got it out the bearing felt decent compared to the new one. i got all my stuff at autozone just cause its close. had to get a new pulley for the ps pump from chevy cause i broke the other one cause i was in a rush and in a parking lot. but other than that they've all been auto zone parts. alternator too cause the ps pump peed all over it.... great placement chevy.... lol alternator relocator sooner or later when i have the money to do an actual build. but for now i want this squeak gone
On my 2000 ls1 from a Camaro just transplanted I had a chirp as described. new belt, new water pump new ps pump & pulley, idlers replaced and the new belt had a chirp. The fix was another new belt. Quiet and now I have a spare in the trunk!!
Both belts were Dayco I believe.
Tom
Tom
Tom
Tom
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I had done all of the replacements as part of the transplant, not the chirp. The chirp started in spite of all the new parts. I wondered if I had got some oil on the belt and caused it, so I cleaned all of the surfaces, belt included, but it didn't clear the problem, but another new belt did.
Tom
Tom
Tom
Tom
Another way to check and make sure it's a pulley, or belt issue and not a more serious problem is to take your belt off, and run you car for like 10 seconds to see if the noise is gone. Sometimes if you replace tensioners with generic brands the alignment of the pulleys can be off and cause squeaks to keep coming back too.
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
Another way to check and make sure it's a pulley, or belt issue and not a more serious problem is to take your belt off, and run you car for like 10 seconds to see if the noise is gone. Sometimes if you replace tensioners with generic brands the alignment of the pulleys can be off and cause squeaks to keep coming back too. ![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
Moderator
If it's chirping belt-to-pulley, I have had some success
with manually scuffing the pulley faces / grooves with
320 grit sandpaper. Of course if the chirp is in the
bearings, you need another plan.
