performance rotors
I plan to motor cross my trans am. It needs brakes and I wanted an opinion on what rotors would yield the best results. Drilled, slotted, or drilled and slotted? Any opinion appreciated.
I know this will sound ludicrous but try a set of Pep Boys pro Stop high carbon rotors. They only make them for the frt so in the back you'll have to use their standard rotors. I put a set on my TA and honestly they ROCK, best rotors I've ever bought EVER.
I just installed brakemotive (eBay) package and love them! Was very skeptical of the price and ordering eBay brakes, but these are the best brakes I've ever installed of an fbody and NO squeaking even with some spirited driving!
2 questions back at you is what is your budget, and do you need one set of brakes for both street use and motorcross?
Drilled and slotted rotor means less surface area, so less braking power. Those same holes also mean less heat dissipation, which leads to shorter brake pad life, and more heat in the rotorz (ie increased odds of warping). Holes in the rotor are often places where stress cracks begin. Plain Jane is the way to go.
No doubt there are advantages for very specific applications in track racing and autocross. Trying to define that exact application is the hard part. For that you need to know all parameters (car weight, top speed, type of track, weather). What works for one guy might not work at all for the next one. For those who might only see several trips to the track per year the money might be better spent in quality solid rotors, brake pads, tires, high boiling point brake fluid, improved ventilation to wheel wells, training on improving your braking techniques, etc. Brake mods almost seem to have the same cult-like following as different motor oils. Everyone has their favorite and swears by it. For higher speed racing (and in the rain) there's probably usefulness for the slotted/drilled rotors. The professional racers frequently change brake set ups to accomodate all the different tracks they see. Rather than slotted or drilled rotors maybe a thicker metal one would perform better for occasional track use. It might be interesting to see what the NASCAR and circle track guys typically use. If you can afford carbon (like the F1's) that's an option.
