Engine breaks up at 5000 rpm's!!!
The problem that I am having is that it feels like my car starts to die at ~5000 rpms. It sounds like the top end of the engine is about to fly out of the valve covers. I was thinking maybe it was a rocker arm but wouldn't that make the noise all of the time. So then I started thinking that maybe it is fuel pressure but when I bought the car the owner was having it replaced. (I've only had the car for about 2600 miles). Any help would be greatly appreciated. Oh by the way the ses light has not come on. Does this mean there are no codes. I only use 93 octane gas and the car only has 27000 miles.
Stranger things have been known to happen.
I'd pull the valve covers to look for broken parts first. But given the description, at a higher rpm power goes away and makes noise I'd think float. If there was a broken rocker or something you'd think it'd make noise all the time. It's really easy to check for valve float, just hook up a vacuum gauge. If vacuum at that specific rpm starts to flutter, then a spring just went bad.
Thanks I'll Give That A Try. When I Mentioned The Rocker Arms I Was Referring To The Little Needle Bearings Going Out Not Really Breaking One. I Have Heard That Ls1's Had A Problem With That. Did They?? If So What Is A Lower Cost Set Of Stock Ratio Rocker Arms???
Yes ls1 rocker arms have been known to fall apart. I call that broken, because they aren't serviceable. If you need stock rockers, try looking in the "for sale" section of this site. Lot's of people upgrade their components and sell the stockers.
Yea I Have Seen Them In There From Time To Time. But In My Way Of Thinking If You Have To Replace A Stock Part And Somebody Makes One Better Then Why Not Upgrade. I Wanted To Keep The Stock Ratio Because I Plan On A Cam In The Future And Most Say Don't Use 1.8 Ratio.
edit - also you might want to hit up Nate @ NastyPerf, or Predator-Z. I think Harland and NastyPerf were working on a deal where they work over your stock rockers, and install a c-clip on it to prevent needle bearings from coming out. requires machining, but installed if you ship them your stockers its like $260. dunno if it went through or not.
