Exhaust Question
Exhaust Question
Ok i want to order full exhaust for my car, if i order pacesetter LT's and a y-pipe, and then a magnaflow catback, will that be full exhaust? Or is there a I-pipe that connects the caback to the y-pipe?
So you're pretty much all set - just gotta shell out the $$$.
Originally Posted by Switchblade
If you plan to run cats then you'll need to get these as well. If not, then you pretty much have what you need for the entire exhaust system. Also you would probably need some 02 simms or extensions since you are using LT's. In regards to the magnaflow catback, it will come with all the parts (including the pipes) needed to install it.
Originally Posted by Dip Stick
get the high flow cats. though my installer had a time getting them to fit
