oil pressure
oil pressure
what should it be at normally? i got in 2day and it was over 70 and i know thats not right. was a lil low on oil, but still seems high to me. idling im just under 60.
1 Post
wow wat the hell i thought the ls1 oil pressure is normal when its high mine runs around VERY close to 80 psi when im cold but i drive very very slow when its close to that high but then when it gets hot i run around 45 to 50 at idle im not to sure if this is normal since my car has 77K and i use mobile 1 5w30
1 Post
well actually yesterday my car was running operating temprature and then i shut the car off for about 2 hours then when i started back up the engine was still warm but not normal temp so i let it warm up then i was coming down the canyans to get home and i was in 4th gear about 2,500rpm cruising down the road untill i noticed my oil pressure past 80 which scared me and then i just put the car in neutral untill i got to the streets but that high of an oil pressure gets me a bit worried, i could blow a seal or something else can I? but i also have a catch can to be on the safe side as well i know i dont get to much oil in there so thats good. but im not to sure if i should be worried bout my high oil pressure!
