My car makes a thump noise???
well sometime wen i go over speed bumps or just stop too fast ill hear a thump like a knock on my wheel on the drivers front and back usually theyll only do it once and a wile...i it started happening wen i did my brakes.
Do you have aftermarket longtube headers? If so My guess would be that when you go over the bumps the headers are banging off of your floorboard. I believe one of the sponsoprs on here like Thunder Racing or Tbyrne motorsports sells header hanger.
no it does not hit... im thinking it might be like something loose..
its like something not screwed on fully so wen i go up bumbs or brake fast it moves forward and backward...
im thinking it might he the brake pads cuz it sounds like its comming for the front tire and the back tire...
did i miss anything i just bought some atozone ones and compressed and putt them on and bled the brakes...they work great
o my cars all stock
o my cars all stock
yeah well he said it was something that sticks em to the pistons so it wont move....
un ok tomoro imma jack up my car...
the back driverside and front makes noise....what should i check for wat should i tighten it thats the case?
o well the front drivers side started making noise yeasterday wen driving it hard
but some streches of the freeway are so fucked up![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
well i its a lound knock wen i tur the weels all the way to onside and then all the way back to the other side. like wen imm getting out of my driveway
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I just started to hear te same noise but i just added long tubes and x pipe. but when you find out what it is post it up maybe i have the same prob. when i hit a bump i hear the noise too.
well sorry if it looks like im not taking there opinions...but i am cheking my stock headers and exuast, and the strut tower and it all looks good...
i just tend to ask more questions wen they respond....
Oh and i just found out that i have cut springs
ive been under my car and im wonderign if the brakes supposed to be loose like just enough to move the rotor in and out??? they bracket for the brakes dont move at all tho
o my cars all stock
o my cars all stock
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
does it do the noise when going forward after you have just backed up? if it does it could be the brakes were not seated properly in the caliper, or the retainers may not have been put back on.
well i checked everything and its all good i guess....
ive been looking and were my wheel goes through and has the joint the hood relese cable it touching it...is that normal...
i makes noise wen i turn right an then left that what ive seen and reverse and forward, everything else works fine.
well tonight driving to the bank something happend...i geuss waterver it is..its supper loose..i can feel the vibration adn hear it sounds like if it was my sway bar but its still on..
any ideas?
any ideas?
yeah pops but sometimes only an....
and mostly wen i go right to left.....and now wen im movine it does it all the time just less loud and its like a creeking noise with a lot of vibration commign from the drivers side suspension
