shreveport/bossier hang out!
#3641
Before you pull all of that back off, I would atleast look through the oil plug hole and make sure the pick up tube is not to close to the bottom of the pan and not allowing it to circulate. I say that cause I remember you saying it was bent a little, but you didn't say if it was up or down.
#3643
It's not hard. You have 6 bolts (3 on each side) that go along the subframe. Take the front one out on each side and then run it back in maybe 4-5 hand turns then take the back two on each side completely out. This allows the k-member to tilt backwards and let the pan slide to the rear. Before doing all of that you'll have to take out the motor mounts bolts, disconnect the steering shaft, disconnect the bottom of both front shocks, and suspend the motor with a chain, hoist, cherry picker, whatever will work. It sounds like alot but it ain't and it makes tons of room. You'll be able to jack the motor up about 3 inches and the k-member will drop probably 3-4 inches. Enough room to get ratchets, wrenches, and arms in there if need be. Makes it alot easier to torque the bolts also. You should be able to rent a cherry picker from any parts house. They may even deliver for you if you ask.
#3644
I think ill just do it like i did last time. All i had to do was pull the trans, y pipe and the pass motor mount bolt and jack the motor up in the front and rear, then i cut a 2x4 to fit between the block and k member for it to support the motor and just go to work. It took 15 minutes to put the trans in last night, the reason it took 2 hours to get it out last time is because the converter bolts were stripped and i pulled the trans with the converter still on the flex plate which ='s a PITA. Now its just 17mm bolts so i wont have that problem. I think i can have the pan ready to pull in about 2 or 3 hours and just wait till sunday night before i remove it and cover the car.
#3645
hay guyz seen the new f&f movie its pretty dam cool im glad they used more muscle cars then imports in this one... I HAD A CHECK ENGINE LIGHT COME ON AND THE CODE WAS SOMETHING ABOUT IT TRYING TO CLEAN OUT GAS OR SOMETHING WITH THE SMART PUMP THE GUYZ AT LG MOTORSPORTS AND RED RIVER CHEVY SAID IT WAS A EMMISSIONS CODE IF I UNPLUG THE BATTERY FOR 30 MINS SHOULD THAT TAKE IT OFF... IMPUMPED FOR SUNDAY ARE WE MEETING AT THE SAME SPOT AND SAME TIME
#3646
Tough Mudder
Damn that's an ugly post.
Cody and I had a good time last night at Steve and Carrie's. I'm sure everyone there will vouch for me when I say, "I'll kick the **** out of an oil pressure sending unit!" My arms look like I've fought Wolverine. It's a good thing I heal quickly.
#3647
I'm gonna be at the same meeting place at the same time as last time. Chaz I have a scanner with me so if it doesn't go off I can turn it off and maybe it won't come back on. If it's just something like the AIR it won't hurt anything anyway, but we'll see exactly what with the scanner. See whoever is going at the LeBossier around 10am.
#3650
I think me chad and chazz might just catch yall there or something. my ol lady and son are goin this time. cad is gonna swing by my house and pick up my tires for me so we don't have to take two cars. That is unless everyone wants to meet at pilot right by my house
#3653
sounds good. let me check with chad since he is bringing my tires and we will be leaving at the same time. yes in haughton. me the wife and kid are all gonna ride in the t/a there. so no tires in the back seat this time. he is gonna call me tonight and set up a time to meet me there so we don't have to take 2 cars there. ashley loves photography so I am sure she will be glad to take some pics
