shreveport/bossier hang out!
#6664
Any callouts when the track reopens? Years ago by this time parts were flying,money was gone and **** talking was high........what happened?
Did everyone get soft and start posting youtube videos on here!?
#6666
Track is closed, we can post youtube vids till our heart's content.
I am looking forward to some passes in mine while the weather is still cool. I may have to borrow some slicks for a new PB, bc the Nittos arent gonna get it. I aint chunking them till they are bald though
#6668
Well damn, finished the timing cover gasket andx geuss what. Oil pan gasket leaks now.can the pan be dropped enough to reseat the gasket without pulling the motor? Now I need to flush the old coolant out and in with new tmrw then I can drive it again. Son of a... now I need a beer
Btw the pan leaks on the passenger corner of the timing cover, looks like the gasket. Didn't seat well in the groove. Maybe I can flex the rubber into place without pulling the pan? DAMNIT I'M UPSET!
#6669
So I use a sc@rewdriver and straighten out the oild pan gasket and put some rtv in the cover wear it meets the block and timing cover. Let it roll outta the garage not wanting to start the car. And let this sit while I wash the car for the first time. I pull the e- brake and POP, the cable or something snaps...just my luck
#6674
I didn't know ther was a proper gap, I figured that's what the dowl pins were for. I rtv'd it and it seemes not to leak now or at least not as bad but will work till I can get time to do the oil pan gasket. Now I have to fix the ebrake since its an m6. Plus I think the battery needs replaced. I think I need the vanity plate MNY PIT. Oh well, its fun to work on it, just expensive
#6675
The deal is that the factory oil pan gasket is made out of material that becomes brittle with age and if you dont drop the pan a bit when pulling the timing cover back, if will break the gasket up. Did it with my first cam swap and it leaked horribly. You can try rtv but you will most likely not be satisfied until you replace the gaskets. Lt1's are ******** haha
#6676
This one is rubber and you can tell its be replaced. I had to replace the balancer bolt with one that would tighten up as the factory bolt kept pulling loose, worried bout that but works for tonight
#6677
Funny you posted this. I had a birdie on my shoulder yesterday chirping your name. A certain pewter camaro is lookin for you............
#6679
Rockstar
As they so eloquently put it, "You deserve it".
http://www.youtube.com/watch?v=fd1hq...layer_embedded
#6680
anyone need a window switch? its a distributorless switch so i cant use it. It has 3000 and 6200 pills in it right now. Just looking to get back what i got it for. $60 delivered!
http://www.summitracing.com/parts/MSD-89561
