whats the record for stock 5.7 ls1 block on spray
Old 10-20-2009, 03:29 AM
slowss02's Avatar
Default whats the record for stock 5.7 ls1 block on spray
does anyone know the 5.7 stock aluminum block on spray record?
and whats the record of stock bottom end on spray record?
slowss02 is offline
Old 10-20-2009, 03:31 AM
camscam02's Avatar
bottom end is 9.64 or .66. one of those.
block.. no clue.
camscam02 is offline
Old 10-23-2009, 04:13 PM
Chris@NitroDaves
Guest
Posts: n/a
block.. no clue.
Same here.......
i believe it's a 9.64 ( I think it might actaully be faster than this but im not 100% sure ) and i have no clue on the block
I think someone has been real close to the 8's if not in the 8's on the stock block
Old 10-23-2009, 04:15 PM
jdiddyws6's Avatar
I thought that was on motor by tsp?
jdiddyws6 is offline
Old 10-23-2009, 04:18 PM
Chris@NitroDaves
Guest
Posts: n/a
They went 9.82 i beleive...Or at least thats what their site says.
Old 10-23-2009, 04:19 PM
jdiddyws6's Avatar
I thought they went faster this year.
Old 10-23-2009, 04:26 PM
Chris@NitroDaves
Guest
Posts: n/a
They might have i'm not 100% sure what they ran this year.
Old 10-23-2009, 04:44 PM
jdiddyws6's Avatar
Stolen from drag racing tech
https://ls1tech.com/forums/drag-raci...rd-9-66-a.html
Old 10-24-2009, 07:54 PM
CalSpeedPerformance's Avatar
I "believe" we've ran the fastest mph on the stock bottom end LS1 (at 4100 DA 103 deg day, 130+ deg track temp, peddling the car down the track till the 330ft) about a month ago.
10.01 @ 141
We are headed back to the track with a few changes on Nov 7th (2 weeks)...hoping to be the new fastest stock bottom end car in the country
CalSpeedPerformance is offline
Old 10-24-2009, 07:59 PM
bret97gsx's Avatar
in an F body..
bret97gsx is offline
Old 10-25-2009, 02:49 PM
MelScrilla's Avatar
10.01 @ 141
texas speed went 9.82 last year on a stock bottom and 9.66 this year, your on your way but you have a way to go.
MelScrilla is offline
Old 10-25-2009, 08:38 PM
We've made a few changes for our runs in two weeks
141 in 4000+ DA ...if that means anything to you, present weather is been about 1000 ft DA...we are expecting some great stuff. Our race weight is pretty close to the same as Texas Speeds Camaro now with all safety changes/adds (Putting chute/sheetmetal wing/halon system etc in car now since we expect mid 8's with the new motor as soon as we get done with the stock shortblock stuff)
Old 10-26-2009, 02:01 AM
gold98Z28's Avatar
OP is your question stock short block or stock block/cubes with forged internals? i know there are a couple on here that went in the 9.3x's with stock cubes @145mph. i know baked on here was after that record last year with the potental to break it if the car ever worked at the same time the track was there. he went 9.36@145 last fall with stock front suspension and about 3400lbs....
gold98Z28 is offline
Old 10-26-2009, 08:26 PM
Orangepeeler's Avatar
I think the OP was asking about the stock bottom end on nitrous. I believe that the 9.66 Texas Speed ran was just H/C/I NO spray. I don't know what it would run with the bottle turned on.
Orangepeeler is offline
Old 11-01-2009, 03:26 AM
M1T/A's Avatar
Thats with a very light car i pressume.
M1T/A is offline
Old 11-07-2009, 11:12 PM
slowgoat's Avatar
You all must be talking about some sort of record for people who post on these internet boards.
slowgoat is offline
Old 11-08-2009, 03:13 AM
SPEED#1's Avatar
I heard that Calspeed is the fastest as of yesterday!?
SPEED#1 is offline
Old 11-08-2009, 08:04 PM
We went 144 yesterday @ 800ft DA (good DA for our local track actually) on stock shortblock.
Im pretty sure Texas Speed's car doesnt have stock rod bolts which is only slightly unstock-shortblock though. We would go faster but dont want to turn over 7000 on the stock rod bolts and ran out of gear 100+ ft before the end at 144. I wish it would live at 7200 or so and get a little more ET / mph out of it, but ill have to switch from a 3.73 gear to a 3.55 to do that.
Old 11-17-2009, 10:30 PM
slowss02's Avatar
the reason im asking is we went alittle faster then that, but if its not the record i really dont wanna post the times,, we went into xxx range with the ls1 shortblock off the footbrake leaving at 2300 rpms on a single plate..
slowss02 is offline
Old 11-17-2009, 10:32 PM
slowss02's Avatar
we went faster.. was that the record?
slowss02 is offline
Quick Reply: whats the record for stock 5.7 ls1 block on spray
