LS3 Vette HSW plate fitment issues
The HSW is a very thick plate, and the problem is, my TB connector will not snap in because the tensioner is in the way. If I flip the TB around, the power steering reservoir is in the way. There is absolutely no way I can fit it there. I have ran a NOS plate, but it is about 1/3 of the size in thickness of the HSW plate and I just barely had enough clearance from the tensioner.
Does anyone else run into this problem, or do they have a picture of a LS2/LS7 vette engine bay shot I can look at? I saw another LS2 and the tensioner was lower than mine was, so the clearance wasn't an issue.
I did, I was more curious in seeing the engine bay shots for future reference rather than getting the issue resolved.
I spoke with Vortech and they had said for 2009 LS3 they swapped the water pump inlet around.. not sure if that had any other effect on the other accessories.
I did the HSW plate also but on the LS1. It is thick & I was just able to stretch my TPS wire harness out enough for it to snap in place. Its at its limit now. I wish there was an extension harness. But yea your config. is different. I'd like to see what can be done as that is a concern.
I called them and they are issuing me a refund. I think all the signs lead to me staying with the nozzle, haha.
I will try the nitrous outlet one next.
