Where do you put your FPSS?
Old Sep 17, 2010 | 09:47 AM
gillbot's Avatar
Default Where do you put your FPSS?
I was going to install my FPSS right off the fuel rail like is typically done, but I ran across an install pic here somewhere the other day that had it after the fuel solenoid and that made a bit more sense to me. Just looking for more info on where everyone has their FPSS installed?
Old Sep 17, 2010 | 10:27 AM
NHRATA01's Avatar
If it's after the fuel solenoid, it's never going to see pressure, thus never close the circuit, thus never energize the system.
Old Sep 17, 2010 | 10:44 AM
ryarbrough's Avatar
I'm going to be honest with you.... If it were me, I'd mount the thing in the bottom of my trash can.
I hate those things.
Old Sep 17, 2010 | 02:40 PM
Chris@NitroDaves
Guest
Posts: n/a
I would install the FPSS on the fuel rail with the supplied manifold then run your line from the manifold to the fuel noid. This is how it's typically installed.
Old Sep 17, 2010 | 03:05 PM
BLK02WS6's Avatar
X2 on the trash can...
Old Sep 17, 2010 | 03:35 PM
gillbot's Avatar
Yeah, I wasn't going to install one but it was in the kit so why not. I just figured the typical was off the rail as suggested, but I saw the one install with it after the noid which kind of makes sense. If the fuel noid gets plugged or doesn't open, it won't allow the nitrous noid to work. I would think though that a -3an running to a fuel jet would still be enough of a restriction to allow the switch to see pressure. I mean, if it's not going to see any pressure, then your fuel rail won't have pressure either.
Old Sep 17, 2010 | 04:25 PM
Nitro Dave's Nitrous Outlet's Avatar
LOl.. For you guys not liking the fpss. I understand where you are coming from but, It saved our motor 2 weekends ago.. I know alot of people hate on the fpss but truth is its cheap insurance and it works just like it is suppose to when set properly.
Old Sep 17, 2010 | 04:29 PM
gillbot,
The fuel pressure safety switch is designed to keep the system from activating in the event of fuel pump failure. So it needs to be in the fuel feed before the fuel solenoid.
The only thing there is to save the motor from if the system went lean is a lean cut off switch. Dyno Tune offers a nice one. However if you are not going to wore it to a wide band dont waste your time and money.
The best preventive is to make you are using a good quality solenoid designed for todays fuels and good wiring connections.
Dave
 Michael S. Palmer
Old Sep 17, 2010 | 09:25 PM
Grant@NitroDaves's Avatar
LS1TECH Sponsor
an air compressor and DVOM will make the set-up of the FPSS a little easier.
Old Sep 17, 2010 | 10:22 PM
JRracing's Avatar
My fpss is right before it goes into the reg. Then off to the noid.
I got a good question..
If you feel the fpss is faulty, can you just hook the two wires together and the fpss is now unhooked and the kit work ok?
Old Sep 17, 2010 | 10:47 PM
LilJayV10's Avatar
So most people don't use a FPSS?
I am using all HSW stuff, (sorry nitro daves)microedge plus, interface, wideband O2, etc.
Is using a FPSS going to cause problems? If so how?
Is using one overkill, if there is such a thing?
Thanks for any input. I am wiring up my nitrous kit at the moment.
Jason
Old Sep 18, 2010 | 07:26 AM
gillbot's Avatar
I think the biggest problem i've seen with FPSS's is that people don't take the time to set them properly.
Originally Posted by Nitro Dave's Nitrous Outlet
gillbot,
Dave
Dave,
That was my thought but seeing that picture got me thinking. That's where I had it installed and where i'll likely leave it but I had to ask. Never really thought of putting it there to be honest, it just sparked my curiosity.
Old Sep 18, 2010 | 08:47 AM
JRracing's Avatar
How do you set a fpss propperly? I have an adjustable one and I think it comes pre set at 5.5 psi.
Were should they be set at in relation to the fuel psi going to the plate?
Old Sep 18, 2010 | 12:41 PM
gillbot's Avatar
I would say you should monitor your fuel pressure during a run, then use an air compressor to adjust it but i'll let the "pro's" chime in.
Mine came pre-set at 50psi, at idle my pressure is at like 62psi but ive never checked it during a WOT blast so I don't know how far it drops off.
Old Sep 18, 2010 | 01:53 PM
SargeZ06's Avatar
Can't the controller save the motor too if the pump or pressure **** the bed? I mean mine is set to stop spraying if it gets lean at 12.5 or rich at 10.5.
I know what's coming next, if you trust your wideband. Well I would trust it more than I would the FPSS and since it's good enough to count on form my N/A runs.
Just sayin'... I don't have near the experience a lot of you do with Nitrous so I'd be interested to hear what you feel.
Old Sep 18, 2010 | 02:02 PM
Beer99C5's Avatar
Mighta been one of my pics. The noid is a NX Lightning, it has a flow through port, so it can be on "other side" of the fuel noid. For my application it was the cleanest install option, and worked fine. I eventually ditched the FPSS for an AFR shutdown built in to the Trick Performance V Guage.
Below is an 1/8 mile pass (NA) with fuel pressure being logged from the far side of the noid. Racetronics pump, new fuel filter got as low as 47 PSI upper RPM of first gear. The pump recovers on the shift, but you can see if your FPSS is set for around 45 PSI, one could dip into the window for the FPSS to shut down the nitrous during a pass.
FP PSI far right second batch of 4 from the top PIDs logged in magenta
Old Sep 18, 2010 | 04:18 PM
gillbot's Avatar
Nope, that wasn't the pic I saw but great info there!!
I was thinking of setting mine for ~40 psi anyway. Many FPSS's come pre-set at 50 psi and I figured that would be a bit high. That could be why most people ditch them, they leave them set at 50 and they'll drop off the N2O during a pass when pressure drops.
Old Sep 18, 2010 | 09:54 PM
custm2500's Avatar
Ph.D. in HUBRIS
I installed mine in the trash like many/most other people.
