Power loss N/A from colder plugs
Is there much loss using a TR6 or BR7 N/A when you dont want to run the nitrous? Just trying to get a idea if i would expect to see less at the track on motor, if i should run a TR5/6 in the 5.3, then swap to a BR7 when the gas is on or just buy a BR7 and call it good?
You're going to lose a little bit running a colder plug. If you don't mind swapping plugs then run a hotter plug and just switch when you're going to spray. I hit my power goal n/a for now with the br7ef's so I just run them all the time.
FWIW my best motor passes ever was on a day I was running nitrous and some guys wanted to know what my car ran on motor so I made a few passes. I was running br8efs gapped at .33 So I would have to agree that the colder plug will not hurt and if you really want my honest opinion I think tr55s are too hot for a bolt-on car and #7s are probably the best plug to drive around on for a DD plug setup.
You don't constantly foul plugs when DD'ing the BR7EF's? I'm considering running them 24/7 since I'm about to start spraying.
If they don't constantly foul during city driving, that would be a much more convenient alternative than running the TR55's for daily use, then needing to swap to BR7EF's if I planned on spraying that night.
[/B]
[/B]
Ive been running colder plugs since my install on the LT's which has been a few months and i would seriously doubt you would lose any power at all. Just run the colder plugs if your using nitrous and leave them in.
FYI. on the colder plugs you will more than likely get a little more timming in it. We have found little to o loss in colder pluss. the thing that scares people is if you idle tune is mediocre to start the cold plug on start up will make it worse. if your fix your **** tune it will idle and run good and run about the same.
